Old 06-09-2004, 04:40 PM
BugsUK's Avatar
BugsUK BugsUK is offline
VTEC noise and test
My car is a 1996 1.6i SR Coupe.
Since installing the SRI (below pic) I've noticed a loud metallic whining sound at 5500 RPM and above. Presumably this is when the VTEC kicks in. I was just wondering if this is normal with this kind of intake, or is something wrong with my VTEC system? The intake is secured by a metal bracket bolted directly onto the body work inside the engine bay, do you think this is causing some sort of increased resonance during VTEC, or am I just worrying about nothing? Does anyone else experience this? I tried following the diagnostic tests in the manual. The resistance between the teminals on the lock up solenoid was about 16 ohms so I guess that's OK. Now here's where I came unstuck... the manual says follow the DOHC tests for the SOHC engine (D16Y8) as they are the same. So I was going to test the VTEC oil pressure switch.. but I couldn't find it! It's not where they said it should be, so does anyone know where it is or even if the SOHC engine has one? Saying that though, the malfunction indicator light isn't on, but I just wanted to do the test fany way for my own peace of mind. The only other way would be to drive around above 5500 RPM all the time and see if anything unusual happens... Any suggestions/comments would be appreciated. Thanks.
Old 06-09-2004, 05:22 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: VTEC noise and test
don't worry about the sound, it's your intake doing it job. Sucking in air
Empty Pockets Racing Member #1
Old 06-09-2004, 11:23 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
omg.
this gets asked at least once a week, did you try searching? didn't think so. You suck
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 06-10-2004, 01:21 AM
~ls/vtec~'s Avatar
~ls/vtec~ ~ls/vtec~ is offline
Send a message via MSN to ~ls/vtec~
clean engine though!
btw: 100 posts
Old 06-10-2004, 01:36 AM
BugsUK's Avatar
Originally Posted by kicker1_solo
omg.
Funny... I've searched the entire forum for a question about the VTEC oil pressure switch on a D16Y8 and guess what? No results! If you just don't know the answer, or even understand the question, why not just admit it? Don't you think it's lame to flame for no other reason than your own ignorance......??
Old 06-10-2004, 02:24 AM
Re: Re: VTEC noise and test
Funny...I don't remember specifying which question gets asked all the time. I was referring to this one
You're questioning my knowledge? You're a silly little noob lol
2000 BMW 323IT
1954 Ford F100
Old 06-10-2004, 07:57 AM
DCsupra1990 DCsupra1990 is offline
What your hearing is the change in tone an intake makes on your engine. The original intake on the car is designed to silence the car (retarded engineers). So basically with an aftermarket intake installed all of your silencing mechanisms are gone and your car will sound louder and sometimes more high pitched at high rpms. As for the oil pump, i would assume there is one somewhere on the engine because thats how VTEC works. I wont explain the whole concept cuz you probably know or have a good idea yourself how it works. But i can if you would like.
Old 06-10-2004, 05:10 PM
BugsUK's Avatar
Thank DCSupra1990 for a constructive answer. That's what I suspected was happening, but I'm still curious about the location of the VTEC oil pressure switch, described in my rather inexplicit Haynes manual. I suspect the DOHC and SOHC engines differ in this respect. Maybe Kicker1Solo, or whatever he is called, could share his infinite knowledge and simply tell us..... LOL.
We may be newbs now, but who knows..... after 15,128 unhelpful and unimaginatavely critical posts, we too may be clever f*cking "fanatics" as well, one day........
Old 06-17-2004, 10:30 PM
~ls/vtec~'s Avatar
i believe its bolted into ur vtec solenoid
Old 06-18-2004, 02:42 AM
sageuvagony's Avatar
sageuvagony sageuvagony is offline
Send a message via AIM to sageuvagony Send a message via Yahoo to sageuvagony
When I first got my intake I fell in love with the sound! I actually learned that the civic gets loud in a mean way by disconnecting the stock air filter I love the roar of the engine
1997 Integra GSR and 1992 Civic LX
Old 06-18-2004, 03:33 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
I'd forgotten how tiny the sohc intake manifolds are..
I took a friend for a ride (who has a Mustang 5.0) and he got this really distorted look on his face when vtec carried us to 8400rpm.. I laughed when he asked wtf it was, and if he ever heard that sound in his car it means something broke, heh..
Old 06-20-2004, 05:32 PM
~ls/vtec~'s Avatar
get a chip and take it to 9000. see what he says then
Old 06-20-2004, 07:38 PM
B1SiR6A's Avatar
B1SiR6A B1SiR6A is offline
Where is the type R redline/rev limit ?
"Check that young man for nitrous"
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Currently 4th in BHRA All Motor Class...Soon to be 2nd (I hope)
...Theres gonna be alotta slow singin, an flower bringin if I hear my car alarm start ringin ...
Old 06-29-2004, 06:58 PM
JDMrexBoi's Avatar
JDMrexBoi JDMrexBoi is offline
Banned
8.500
Old 06-29-2004, 10:35 PM
Ricochet's Avatar
Banned
Re: Re: Re: VTEC noise and test
8400..
