Old 06-09-2004, 02:04 PM
808race 808race is offline
Electrical Probs. Need Advice!
okay here's the situtation: i was driving my car when i hit second gear, my dash lights went off. Everything was working fine until then. When i got home i noticed my reverse lights and tailights didn't work either. i checked the bulbs and there are all good. any help would be appreciated. thanks.
~Alohaz~
Old 06-09-2004, 02:14 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Electrical Probs. Need Advice!
fuses also if its not a fuse what year/model do you have
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 06-09-2004, 04:41 PM
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
my left rear blinker sometimes goes off too and sometimes no apparent reason blinks a lot faster.
06 Charger SRT-8 black.
Old 06-09-2004, 05:17 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: Re: Electrical Probs. Need Advice!
It blinks faster because the left one stops working. So the other one goes faster. The same thing happens with a burnt out bulb
For Sale 98 Eclipse GS, 5 spd
Old 06-09-2004, 06:23 PM
i got a 96 Rs. I checked all the fuses and the connectors to see if anything got loose and unhooked or anything, found some, but couldn't see where the hell any one of those loose connections where going . My brake lights work but my tailights for nightitme don't. its frickin irrating
~Alohaz~
Old 06-09-2004, 06:28 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
http://www.automotiveforums.com/vbul...aillight+fuses
read up on this and do like it says, i had this same problem
Old 06-09-2004, 06:52 PM
i read it but im not blowing any fuses. Also my turn signals work, and all my interior lights work except the dash (lights up the speedomoter, gas and temp gauges, ect.. ) my tailights and now my reverse lights. My best guess was that maybe a connection popped out when i cracked second. cause i looked under the dash and found like a plug out. but it doesn't seem to connect to anything becasue of the length.
~Alohaz~
Old 06-09-2004, 07:04 PM
check the fuses under the hood. and if it isn't blowing anything, does it come on and off or are they off and didn't come back on?
