Old 06-09-2004, 01:21 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
energizing magnets
is it possible to take a magnet or piece of metal and energize so that it attracts and then de-energize it so that it doesn't attract?
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 06-09-2004, 02:21 PM
psychobadboy's Avatar
psychobadboy psychobadboy is offline
Send a message via AIM to psychobadboy
Re: energizing magnets
you mean like an electromagnet?
My Car
Old 06-09-2004, 02:24 PM
BLU CIVIC's Avatar
調整器
i'm not sure i wanna energize a small piece of metal or magnet...i guess i may be refering to an electromagnet
The name's Adrian
2011 CR-Z - Stock
Old 06-09-2004, 05:23 PM
eversio11's Avatar
eversio11 eversio11 is offline
Send a message via AIM to eversio11
i'm pretty sure if you rub a piece of metal against a magnet it will attract for a short while, then de-energize by itself
"The greatest Americans have not been born yet,
they are waiting
patiently
for the past to die"
Old 06-09-2004, 05:25 PM
BLU CIVIC's Avatar
調整器
i wanna be able to do it at will....in a very small application
The name's Adrian
2011 CR-Z - Stock
Old 06-09-2004, 08:17 PM
MBTN's Avatar
MBTN MBTN is offline
Send a message via AIM to MBTN
Electromagnet. You can make one out of household materials. Find a bolt, wrap it (neatly and close together) in a wire and pass a current through it. I remember doing this way back in 5th grade using big 'D' size batteries.
Old 06-09-2004, 09:19 PM
BLU CIVIC's Avatar
調整器
think if i were to put a small one in a car it would mess up anything?
The name's Adrian
2011 CR-Z - Stock
Old 06-10-2004, 06:09 AM
-GS-'s Avatar
-GS- -GS- is offline
Send a message via AIM to -GS-
It would depend where you put it i guess.
Real Name: Gurpreet
Old 06-10-2004, 12:09 PM
Iron would probably be the best thing to wrap a wire around to use as an electromagnet.
Why do you want to put one in your car?
My Car
Old 06-10-2004, 03:54 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Use an iron ore rod, wrap some insulated copperwire around the iron ore tightly. You will be creating a solenoid, the more turns around the iron ore the stronger the magnet. Attach the ends of the copper wire (strip the about 2Cm of insulation of the ends) to a 12V battery.
Be careful, the solenoid will get pretty hot. The more turns the more current, the stronger the magnetic field, and the hotter it gets.
-Mike
Old 06-11-2004, 12:05 AM
brianneves brianneves is offline
i smell some innovation here with the electromagnet. just a suggestion, if you want a magnet that will use little batery current, then just bust open an automotive relay like to the starter for example and modify it to fit your aplication. im all about trying new things on cars. you should see under the hood of my pontiac! its an ugly mess, but it is alot of never done before stuff. another suggestion, if you want the magnet to push away you could reverse the charge to the iron rod and put a small magnet on the object you will be moving with the electromagnet. electricity one way will push, the other way will pull. ive built alot of these before......
Old 06-11-2004, 01:13 PM
BLU CIVIC's Avatar
調整器
well i'm workin on a project with my car doors and want to be able to flip a switch and have the door stuck in place and flip it again and have the door come off...that's why i wanted to use an electromagnet....have the power hooked up to the car battery...but the applocatoin would be small and the magnet would only be like 1"x1" in size
The name's Adrian
2011 CR-Z - Stock
Old 06-11-2004, 02:48 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
You would need one huge magnet to hold a car door in place. In theory, you could do it, but its not a practicle thing to do.
Resistance Is Futile (If < 1ohm)
Old 06-11-2004, 07:14 PM
zebrathree's Avatar
zebrathree zebrathree is offline
Banned
Same concept for mag locks (security doors).
We flip a switch, you don't come in montherfucker!
Old 06-12-2004, 11:41 AM
BLU CIVIC's Avatar
調整器
well i'm not gonna hold the whole car door in...just where the latch is and flip a switch and push the door open
The name's Adrian
2011 CR-Z - Stock
