Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 06-09-2004, 11:39 AM
WantaLS WantaLS is offline
Question Airbag light keeps blinking
After washing my car, the airbag light flashes continually. This has only gone on for a day. Should I assume it might be a wet sensor or should I take it to the dealership as the car remains under warranty. I wasn't sure if anyone else had experienced similar problems as well.
Old 06-10-2004, 07:45 AM
CGGorman's Avatar
CGGorman CGGorman is offline
Re: Airbag light keeps blinking
New to me. I'd take it in. It'd suck to get in an accident in the rain and find out the hard way your bags don't work .
Chris Gorman -LLSOC Forum Moderator-
2000 LS8 sport (lowered 2", LLSOC Intake, Magnaflow catback, tint, more..)
Old 06-10-2004, 08:33 AM
Quik_LS's Avatar
Quik_LS Quik_LS is offline
Send a message via MSN to Quik_LS
If the system cannot pass check - meaning all the airbags and sensors can be fully test on startup then the system is disabled and the light flashes.
Most likely:
- one of the senors failed, or the wiring to is loose - around various spots in the perimeter pf the car
- the sensor in the driver's seat has failed, or wiring is loose (common - since the seat moves back and forth all the time)
- the clock spring wiring in the steering column failed to the driver's air bag
The dealer can quickly diagnos.
Quik LS - Austin, TX
more, more, more.....
#0018 ESP SCCA solo2
LLSOC.com - President
see my mean LS
see my Lotus Esprit - Quiker
Old 06-10-2004, 02:24 PM
joyofsix joyofsix is offline
airbag light of death
took it to the dealer. $160 bucks down the drain, something to do about a electrical sensor, but I dont have to worry about that bag blowing up in my face.
Old 06-11-2004, 09:51 AM
CGGorman's Avatar
What happened to the warranty???
Old 06-16-2004, 09:07 PM
You were exactly right! I picked the car up from the dealership yesterday. The light was on due to a loose connection under the drivers seat.
Most likely:
Old 06-17-2004, 10:50 AM
Quik_LS's Avatar
good to hear that you're fixed up!
see my mean LS
Old 08-01-2006, 04:37 PM
zman33 zman33 is offline
Airbag help
If anyone still on this pleaselet me know where the clockspring is and the Airbag fuse. Mine has turned on and won't go off. So it will not pass inspection? I have it 2 years no problem then bang it came on..
Old 08-01-2006, 07:58 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
What year is your LS, and is it the V6 or the V8?
-Rod
Old 08-12-2006, 06:03 PM
CanadianG's Avatar
CanadianG CanadianG is offline
Send a message via ICQ to CanadianG Send a message via Yahoo to CanadianG
I have a 2003 LS V6 and Im getting a code13. Can anyone help?
Women call my bedroom the COCKpit!
Old 08-14-2006, 04:35 PM
Got it. It works!! Thanks
Old 08-15-2006, 10:49 AM
Quik_LS's Avatar
see my mean LS
Old 08-19-2006, 10:47 PM
shorod's Avatar
SHO No Mo
Are you sure about that? I don't see that code 13 is a valid Lamp Fault Code. Are you counting flashes of the airbag light in the instrument cluster?
-Rod
Old 09-27-2006, 05:05 PM
Chica73 Chica73 is offline
Red face Re: Airbag light keeps blinking
This is an interesting one to read as last winter I was chipping ice off the front of my car and ever since then, the passenger airbag light comes on when i start the car >> flashes at first, then stays on. I took it to my local guy and he said that I have to take it to a Dealership. Anyone ever hear of the sensor getting tripped cuz of knockin on the front panel of the car? That's the only thing I can think of that I did. It makes me mental
Old 09-27-2006, 06:46 PM
shorod's Avatar
SHO No Mo
When you first turn the key on, the light should be flashing a code before it goes on solid. Count the flashes and post the code(s) here, that will help us guide you to the likely culprit, and maybe help us correlate the suspect to knocking on the windshield.
To read the flashes, you could the flashes between pauses. For instance, if the light does: flash, flash, pause, flash, flash, flash, long pause, flash, pause, flash, flash, long pause, repeat this string a couple more times, then the light stays on constant -- this would indicate two codes, a code 23 and a code 12.
-Rod
