Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 06-09-2004, 11:33 AM
nate811 nate811 is offline
98 Turn Light Switch
I recently bought a 98 with the following symptoms:
1. Turn light switch to manually turn on lights does not work (has twighlight setting, when turning switch it is apparent that it doesn't work).
2. Taillights do not come on at night with the headlights.
3. Dash lights do not come on (only affecting speedometer, fuel gauge, etc. directly above the steering wheel, other lights such as radio and time display work fine).
4. Right turn signal often will not blink.
I was considering starting with trying to fix the light switch problem and would appreciate advice on what that involves or suggestions as to whether there may be another cause for the taillights and dash light problem.
Old 06-09-2004, 07:56 PM
oldsdad oldsdad is offline
Send a message via Yahoo to oldsdad
Re: 98 Turn Light Switch
Look back through the posts there is a very detailed posting on the mutifunction switch disassemble and fix.
