Old 06-09-2004, 02:05 AM
bamboo bamboo is offline
body work
i have a white dx with the ugly black trim. I want to remove the trim but I wanted some feed back on what I can do replace the trims. I want my car to be all white so if any one can help it would be most apreciated
Old 06-09-2004, 03:28 AM
oldschoolcivic's Avatar
oldschoolcivic oldschoolcivic is offline
Re: body work
The easy thing to do would be to take off the trim and cover the holes by welding or fiber glass, only thing is that the grove will be there. You could weld some sheet metal over the grooves or even fiber glass over it but it wont be as strong.
Old 06-09-2004, 07:50 AM
viper_2_4's Avatar
viper_2_4 viper_2_4 is offline
Send a message via MSN to viper_2_4
Re: body work
you could just paint the trim......people do it all the time, personally I like the contrast of another colour and black trim.....
Old 06-09-2004, 08:57 PM
shaddr3 shaddr3 is offline
Send a message via AIM to shaddr3
Re: body work
Just weld it. Sand down the weld, then fill in any gaps, then sand down more. Welding is the way to go on plain metal like that. Only use fiberglass if part of your body actually uses fiberglass.
89 CRX Si
B16 | BW Body kit | 17" 8 Spoke | Airbagged
Old 06-09-2004, 10:38 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
Re: Re: body work
welding is a good way to warp your doors if you're not careful, fiberglass is the safest way to go and just as good if done right.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 06-09-2004, 10:40 PM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Re: body work
sell me your trim if its from a hatch. My BF needs them for his '89 hatch
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
Old 06-10-2004, 01:34 PM
Thumbs up Re: Re: Re: body work
Originally Posted by kicker1_solo
welding is a good way to warp your door, fiberglass is the safest way to go and just as good if done right.
I've shaved two S10's and welded it clean, no warp bud!
89 CRX Si
Old 06-10-2004, 02:38 PM
audioquattro audioquattro is offline
Re: body work
fiberglassing directly to metal isnt the best thing to do, because metal and fiberglass have different expanding qualitys, thus it could potentially fall off in years to come, i have shaved doors and mouldings from 4 of my past cars with no warping problems from welding, you should be fine
Old 06-10-2004, 10:50 PM
Re: Re: Re: Re: body work
so have I, I'm not saying that it happens a lot, but if someone has to ask about shaving then they don't need to be welding on a car.
^me
2000 BMW 323IT
1954 Ford F100
Old 06-11-2004, 12:02 AM
Re: body work
Put on some gloves man!
89 CRX Si
Old 06-11-2004, 12:06 AM
lol, they were getting in the way, and I was just doin' tiny tacks.
2000 BMW 323IT
1954 Ford F100
