Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 06-08-2004, 10:43 PM
DevilleItalia DevilleItalia is offline
Send a message via AIM to DevilleItalia Send a message via Yahoo to DevilleItalia
1997 Deville HVAC Fan Not Working
Hi Guys.
This is my first posting here. It is also the first problem that I have had with my Deville since I baught it 3 years ago. I was driving the car today(90 degrees) with the AC cranking. Then all of a sudden the fan stopped( only the fan), not the compressor. Suddenly the fan came back on and then died again about 20 seconds later. When the fan died the second time, I heard a popping noise and smelled a strange odor. The popping noise sounded as if rubber diaphragm or something burst. There is still power to the fan motor, as far as I can tell. Is my fan motor blown or is it a relay???? I would appreciate any help you can give me. Alan
Old 06-09-2004, 04:37 AM
michelq michelq is offline
Re: 1997 Deville HVAC Fan Not Working
your blower motor is bad.i hope you do not have north star eng, it is expensive to fix
Old 06-09-2004, 08:18 PM
Thanks,
I do have a northstar. I am going to attempt to fix it myself. Alan
Old 06-18-2004, 08:53 AM
tuffy tuffy is offline
it isnt too bad to do just remove coil pack and remove fan in 3 pieces by un bolting all pieces
the just reinstall in reverse order inside housing
Old 06-18-2004, 08:33 PM
Jed Rule Jed Rule is offline
I found the three wire connector for the fan motor burned the large red wire. Just had to by-pass the connector and permanently solder the wires together.
Old 11-13-2004, 05:29 PM
NY3JAYS NY3JAYS is offline
Is this the same procedure for a 96 Deville? I just experienced the same problem, only with the heater on. Napa lists a resister pack...is that whats on the back of the fan or is it located somewhere else?
Thanks,
Jim
Old 11-15-2004, 04:47 PM
tampaFD tampaFD is offline
the module goes out often in the car. also be sure that the spark plug wires are off the motor housing as they will kill it
Old 11-15-2004, 09:10 PM
Well, it turned out to be the blower. Got one at the local auto parts store. What a job!! I had to cut the housing in 2 spots, remove the coils, and still fight to get it in. Once it was in, bend the metal back and now I am looking for sealer. I have duct tape over the top and front to seal. Any ideas what to coat the housing with?
Jim
Old 12-04-2005, 10:17 AM
57ringo 57ringo is offline
Re: Re: 1997 Deville HVAC Fan Not Working
Jim
The heater fan quite working on my mom's 96 deville the other day. She said she drove it and the heater never worked. I looked at it today, all the fuses check ok and the big red wire has power but there is also ( i think)a black and grey wire in the connector to the fan motor. Is the black a ground and what's the other for? The big red wire is hot with the key on or off. How should this be checked?
