Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-08-2004, 10:32 PM
etruaty etruaty is offline
BOV noise
what would cuase a bov to make a fluttering noise? Any Ideas? ALso I have a drag 3 turbo kit on my 2000 civic ex, what rpm should it boost?
Old 06-08-2004, 11:45 PM
MexSiR's Avatar
MexSiR MexSiR is offline
Send a message via MSN to MexSiR
Re: BOV noise
It a blow off valve that releases or rather controls the extra pressure from the turbo.
Honda Civic 1999 EBP SiR
Im not as fast as I am furious.
1/4 mile = 15.347 (sealevel)
Porsche RS America
BMW 323 01
Pictures of my ride (Pictures)
Old 06-08-2004, 11:50 PM
Re: Re: BOV noise
I understand that, I just wan't to know what to do to fix it so its not fluttering .
Old 06-08-2004, 11:55 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: BOV noise
what type of bov is it exactly?
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 06-08-2004, 11:56 PM
Re: Re: BOV noise
its a blits dd, comes with the drag 3 kit
Old 06-09-2004, 12:20 AM
Re: Re: Re: BOV noise
does that make a difference
Old 06-09-2004, 12:45 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Re: Re: Re: BOV noise
cheach to see if the vacume line is attacher to the b.o.v. the fluttering noise can be that the vacume line is disconnected which leads the bov to be shut causing a back spining action on your turbo.. chech if the vacume line is connected i had this similar problem with my car.. also if you car feels sluggisht its a vacume line not connected or a leak some where in your system
1
Shift_BOOST
97 s14
Old 06-09-2004, 01:34 PM
YellowITR479 YellowITR479 is offline
Re: BOV noise
I never even had the vacumn line on my BOV cause I never knew where it went until I seen a vacumn cap on my intake manifold. That fluttering sound might have something to do with its adjustment. Are you sure that that fluttering sound isnt your wastegate...i know mine makes a lil flutter sound.
I have a Type-S GReddy and I dont really like it, I want the loudest one possible....any suggestions?
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 06-09-2004, 04:32 PM
DeleriousZ's Avatar
Re: BOV noise
HKS super sequential is pretty loud i think, and there's another one by HKS(i think) that's called a Supersonic.. that's gotta be loud just from the name
Old 06-09-2004, 07:00 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
Re: BOV noise
Run a stock type BOV, one that has an outlet pipe, not an air horn to amplify the sound. Then run a hose from the outlet to the intake pipe for your turbo. The noise will be barely noticeable, if at all. Very very rarely I'll hear it on my dad's audi TT, nor on any of the turbo Volvos.
Old 06-09-2004, 08:28 PM
turbo2nr's Avatar
Re: Re: BOV noise
the loudest bov is the turbonetics rfl (real freakin loud) its huge and scares little unsuspecting childer at play into making them car and wet their pants (j/k)
1
Shift_BOOST
97 s14
Old 06-10-2004, 12:15 PM
Re: BOV noise
oh really....hmmm....sold
I think i have hear of that BOV before
