Old 06-08-2004, 10:31 PM
dracer398's Avatar
dracer398 dracer398 is offline
Send a message via AIM to dracer398 Send a message via Yahoo to dracer398
Question 1995 GTP Will not crank. Have power to accessories
My son has a 1995 GTP 3.4. He drove it to work. When he was going to leave the engine would not crank. He said that the "Security" light had been coming on. We tried the spare set of keys thinking that something happened to the chip in the key but it still would not crank. Anyone have any ideas? Thanks!
Brian
Old 06-13-2004, 05:18 PM
IH8RICE IH8RICE is offline
id try the ignition coils or the starter if either one of them are bad i believe u can still have power to accesories but wont start i believe any way i have a 1995 gtp also but havnt had any problems since the tranny was rebuilt in february and i got 133k miles
Old 06-13-2004, 09:48 PM
GTPCatz GTPCatz is offline
Banned
Re: 1995 GTP Will not crank. Have power to accessories
Look at the key does it say something like "PK" on it...if it doesnt you probally dont have a chip in the key, nor does your car require one.
I have found that many People think they have the GM PassKey system in their car and they do not
I would check your Battery....Crank Sensor, Plugs, wires, and the above comments
Old 06-15-2004, 06:14 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
If your car is a 95 and has the DOHC 3.4 engine definetly is the battery. My Z-34 sometimes before installing the 120amps alternator would work the radio, lights, horn and will not cranck the starter. At this day I do not know why these cars(the ones equiped with the 3.4 DOHC engine) drain the battery just being parked. I have somewhat healed the problem just disconnecting the aftermarket alarm the car had. Does your car has an aftermarket alarm or a amplifies sound system that could be draining your battery?
Old 06-16-2004, 12:55 AM
nah id say mechanical ive got a 4400 watt system in my car along with 2 extra batteries where the spare used to be and a 180 amp alternator if the batteries draining some thing is touching and grounding the power or some things not hooked up right im running an everstart max in the front and 2 yellow tops optimas in the trunk plus a 5 farad capacitor and i dont have any troubles. DOHC 3.4 95 GTP that guys got a massive headache from my system pounding!
Old 06-18-2004, 12:45 PM
GTPgirl's Avatar
GTPgirl GTPgirl is offline
Send a message via ICQ to GTPgirl Send a message via AIM to GTPgirl Send a message via Yahoo to GTPgirl
My '94 SE did that... and the older keys, you can see the chip in them. Well, actually, it's a resistor, but anyway, it's below the head of the key, very visible. Anyhow, my security light stayed on, and the car wouldn't start. My dad found out it was the jumper harness, a bit of wiring up under the steering column. Cost about $1 to make another one, but it took a while to put together. I'd check that first.
GTPgirl
Black 1998 Camaro - currently driving
Black 1999 Grand Prix GTP - burned March 2008
Plum Crazy 1970 Dodge Challenger - work in progress!
