Old 06-08-2004, 09:59 PM
CR50HC CR50HC is offline
Putting CRX Si Cam into D15B2
Hello again folks. I've been absent from the forum for a good while now. I have been working my butt off to save up the money to redo my suspension work. I only did simple stuff. I had some worn tie rods and bad bushings. With your advice, I got them all repaired. I have to tell you, the car is a totally different machine. It rides, handles, and brakes much better. Thanks for the great advice!
Now, on to my questions. My 89 CRX DX is "blessed" with the D15B2 engine. I'm to the point where it is about to be overhauled. It has 217,000 miles on it and uses some oil at 3,000 rpms and up. I'm going to pull the head and get it rebuilt, replace my rod bearings, oil pan gasket and as well as the rest of the engine gaskets and seals. I know I should probably look into an engine swap but, my wife prefers to keep the stock engine. Hell at 40 MPG I agree with her! I've heard that I can put in a CAM from an 88-91 CRX Si into the D15B2 engine. Is this true? if it is, what kind of performance gain can I expect to get? Thanks for the help folks!
Troy
Old 06-09-2004, 07:53 AM
viper_2_4's Avatar
viper_2_4 viper_2_4 is offline
Send a message via MSN to viper_2_4
Re: Putting CRX Si Cam into D15B2
I would imagine 1-3 HP max from the Si cam.......you can also take one from a 88-91 Civic Si.....
Old 06-09-2004, 10:21 AM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
I would also think about putting the tranny from the 88-91 crx si onto your d15, it has better gear ratios IMO. And if you wanted to you could also swap the DPFI to MPFi, that would give you the biggest power gain
KoRnSaQ
Old 06-09-2004, 03:33 PM
Hybrid1990crx's Avatar
I think the Si cam would give you more of an increase than 3 hp. Im thinking for on the terms of 5-10 depending on what RPM you are at. You'll feel it alot more after 4,000 rpm. I've had people ask me if my car "had a vtec" because when I hit 4k my engine tone changes and it really starts to pull. And thats my d16a6.
Old 06-09-2004, 03:37 PM
diegoaccord's Avatar
diegoaccord diegoaccord is offline
If I remember, the D15B2 head, and the D16A6 heads are the same. Injection, and manifold are the differences.
My cars:
Civic coupe EJ1. B16A, EG6 cluster. Wrecked/parting.
CRX DX ED8. DOHC ZC, I/H/E.
EJ1 Civic Si . Screw Hatchbacks. Coupes just look better. Period...
Old 06-09-2004, 05:36 PM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Re: Re: Putting CRX Si Cam into D15B2
He's right, I did the Si Cam swap with my DX motor, and I noticed a big differece after 4g's really starts to pull.
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 06-09-2004, 09:36 PM
Thanks for the valuable info folks! I found a Cam and was thinking about buying it but, wasn't sure if it would work....
Old 06-09-2004, 10:22 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
Ive been asked that too bc at around 3,000 to 3,300 rpms its like wrwrwwrwrwrwWRWRWRWWRWR. Some other dude asked me but he didnt know shit and tried to say he got a type r swap for $1,600. By the way i have a stock d15b2
1991 Honda Civic DX Sedan
