Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 06-08-2004, 07:15 PM
logik23's Avatar
logik23 logik23 is offline
Banned
Send a message via MSN to logik23
S14 Sr20det
If this has already been answered I'm sorry, I didn't find it.
I heard that the S14 SR was harder to modify because of the variable valve timing and that it wasn't worth it because it didn't do much. Is this true? And is an S13 SR harder to get into an S14 chassis then the S14 SR?
Old 06-08-2004, 11:58 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: S14 Sr20det
supposidy vvt is harder to tune at high hp and will get in the way when making over 400hp.. for the price of a s-13 sr20det to a s-14 sr20det most people go with the s13 b/c its hundredes less then the s-14 and basically the same motor..
both motors fit the same in ant s-13 or s-14 chassie
1
Shift_BOOST
97 s14
Old 06-09-2004, 12:40 AM
logik23's Avatar
Banned
K, thanks.
Old 06-09-2004, 03:02 PM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
The ports have to make a sharper turn to fit under all the VVT stuff too. so the S13 heads flow more.
its not like the Hump tops cant put down the same amounts of power as the Flat tops. its just that all the VVT stuff usually gets taken off at those power levels (cams, Cam gears). so why waste the money unless you want the lower milage?
Old 06-10-2004, 06:22 PM
HighwayRacer HighwayRacer is offline
Send a message via AIM to HighwayRacer
Re: S14 Sr20det
Takumi's didnt have VVT, so it must be good
