Old 06-08-2004, 06:51 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
detent cable
anyone kno a site where i cant order a complete detent cable kit, for a 700r4?? ive found the cables but i dont see where it bolts and hooks into the tranny..
Old 06-08-2004, 07:26 PM
68chevelle 68chevelle is offline
Send a message via AIM to 68chevelle
Re: detent cable
ok well just so you know, for a 700R4 and a 2004r its not a detent cable. its a T.V. cable. that could be a problem when your looking for one. they are different but many many many people confuse the two. as an example, you can run say a th350 or th400 without the detent cable, but you can NOT, ABSOLUTLY NOT, run a 700R4 or 2004R without the TV cable. heres a sight where you can get a good setup with everything you need. all you have to do it figure out what carb or FI system you have.
http://www.tvmadeez.com/
incase some of the links on that sight arnt working as usual, its through www.700r4.com you can find everything there
<<my engine
<<part of the front end during engine swap
other pictures of my car... click here
Old 06-08-2004, 07:36 PM
Re: detent cable
o damn, i thought they were the same.... well i went to the local parts store they had nothing on a t.v cable nothing at all, all they had wsa the detent, so i thought they would be the same thing... oops, yea i want to get the t.v. cable and be able to get the lock up switch at the same web site, ill check those out
Old 06-08-2004, 08:04 PM
Re: detent cable
alright, i have the steel braided cable and the plate picked out, now i kinda looked at the tranny and i dont see the spring in it that the tv cable hooks to......
Old 06-08-2004, 08:12 PM
Re: detent cable
well its not really a spring, if you look through/read this article it wil explane everything i think. if you just look at the pics it shows how it hooks up and everything, about a quarter of the way down are the ones that show you the best, there are two parts, there is the piece inside the trans that doesn not come out and hook to the lever, and that comes up to the hole and hooks to the tv cable there. look...
http://www.tvmadeez.com/article/index.php
<<my engine
Old 06-08-2004, 08:29 PM
Re: detent cable
oooooo yea, i saw that lever in there but it looks like something could have broke off of it, ok i understand it all now, cool, i also looked at the lock up switch thing in there and have an idea on how to hook it up ,now next question, servos.... hard to install???
Old 06-08-2004, 08:34 PM
Re: detent cable
fuckin a!!! i just went out for a quick look and the hook is broke!!!!!
Old 06-08-2004, 09:40 PM
Re: detent cable
well i would say get the hook off something int he junk yard. should be a problem to find. you can look in GMC jimmys and blazers and stuff like that, and 700 should work. as for the servo, i dont think they are hard to install, i have one fo there servos for my 200 but i havnt put it on yet. if i remember corectly all you have to do is pull on yoru old one so you can get a hook kinda thing in there and brake the old seal then it pops right off and you push the new one on. i think. dont remember for sure. ill see if i can find it somewhere.
<<my engine
Old 06-08-2004, 10:17 PM
Re: detent cable
what if i make a hook?? how much tension or stress is that little hook put through??
Old 06-08-2004, 10:35 PM
Re: detent cable
umm, i dunno. you could try that but it probably needs to be the same legnth and everything otherwise it will probably through off the TV stuff and posibly mess stuf up.
<<my engine
Old 06-08-2004, 10:43 PM
Re: detent cable
yea thats true.. didnt think of that... damn... i always fuck something up... lol
Old 06-08-2004, 11:29 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: detent cable
get the hammer
Old 06-09-2004, 05:34 PM
Re: detent cable
good ole sledge..... ahh the memories.......
