Old 06-08-2004, 05:56 PM
damir831's Avatar
damir831 damir831 is offline
Banned
Send a message via AIM to damir831
need help - newb
Hello, I'm really a newb when it comes to audio. I bought a deh-6500 off ebay. I had a deh-2500 that was only 2 months old. They both had the same harness. When I connected the new cd player, everything looked great, and it looks like it's playing a cd, but there is no sound. I made sure all the speakers are connected right. Even when I switch to "tuner", the station is on, but there is no sound. I tried the new harness and I got the same result. The seller says that the cd player should be working.
I have 2 6x9s and 2 6.5s. I have no amps or subs. Could it be that the cd player is set for an amp or something, and I have to change the options?
Like I said, I'm really a newb when it comes to this, so any help would be appreciated!
Old 06-08-2004, 10:23 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
it may very well be that there is a switch ..... are you sure this CD player even has a built-in amp
Old 06-09-2004, 12:39 PM
damir831's Avatar
Banned
it sells for $200 - 300 so im sure it has an amp. I had an older one in there before, same brand, and that one had an amp. You think there could be a switch on the back? I'll check it out later, thanx
Old 06-09-2004, 01:58 PM
skubydobdo skubydobdo is offline
Re: need help - newb
check in the manual if you got one about turning the built in amp on thru menus while the cd player is on, but not set to play anything. That's what mine does at least.
Old 06-09-2004, 04:57 PM
Audio Guy
normally, the better quality units do NOT have a built-in amp
Old 06-09-2004, 08:12 PM
damir831's Avatar
Banned
oh so you think that's what it could be?
It was pioneers top units a few years ago. So I absolutely need an amp to get this cd player to work? Why does the wiring harness have wires for the speakers then? Shouldn't the speaker wires come from the amp instead of the cd player? If it has a fuse, does that mean it has a built in amp?
Old 06-10-2004, 04:45 PM
Audio Guy
all CD players have an inline fuse .... if it has speakers wires, it must hve some kinda buit-in amp
