No problem, if you can give me until tomorrow I can try and scan the pages from my shop manual for my 2000 LeSabre that pertain to the removal of all of this "stuff". I will also copy the pages for you on the operation of the windows, but first I will have to sort through these huge books and find everything. If you have an email address it would probably be easier to just email scanned copies to you? mine is
[email protected]
Just to prepare you for some frustration however, I have removed these door panels before, and usually there are about two screws hidden behind lamps or door latch panels, and then the rest of the entire molded panel is held in place with these terrible little plastic push pins that attach to the back of the door panel and then push into holes in the metal door. The problem is that unless you have the "special" prying tool for getting these push pins out, then you usually end up destrying at least a couple of them right off the bat, so you will probably want to prepare yourself for ordering a bunch of extra ones for when you re-assemble the door. Your local dealer will sell them two you, usually for a few bucks.
