Old 06-08-2004, 05:13 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
car is running hot
if i let my car run for awhile the temp will go up to the top but if i rev the engine and or drive it goes down to normal
Old 06-08-2004, 05:37 PM
GTO4Life's Avatar
GTO4Life GTO4Life is offline
Re: car is running hot
whoa....weird...
Old 06-08-2004, 07:29 PM
John Pannebaker John Pannebaker is offline
Sounds like faulty thermostat.
Old 06-08-2004, 11:17 PM
Hotshot8792 Hotshot8792 is offline
first, check to see if your radiator fans are working, if they are, then take the thermostat out of your car. If that still does not cure the problem, then you probably have a faulty water pump.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 06-09-2004, 12:48 AM
youngvr4's Avatar
STREET RACING GURU
hopefully its not the water pump, i just fixed that last year. it probably is the thermostat. thanks guys
Old 06-09-2004, 03:01 PM
GrungeAholicVR4 GrungeAholicVR4 is offline
Re: Re: car is running hot
Could be any of those problems, Could even be your actual radiator....that would suck, hopefully out of all those possibles, its the thermostat. Good luck
Old 06-09-2004, 11:20 PM
azn3000GTRacer azn3000GTRacer is offline
Yea i have the exact same problem. It's not the thermostat because even if you drive you should be over heating if it's a bad thermostat. I still havent figured out why mine is running hot when i idle. So when u find out the problem give me back a holler
Old 06-09-2004, 11:42 PM
youngvr4's Avatar
STREET RACING GURU
lol dang you too, yeah i'll let you know man.
isnt that wierd though
Old 06-10-2004, 12:31 AM
hiddendialect hiddendialect is offline
my 96 ta just started to overheat as well. i replaced the thermo and it still did it, so i had it checked out and they said it was a leaking water pump and a leaking radiator. but i think they just want more money from me, so im starting with the water pump to see if it fixes the problem
Old 06-14-2004, 05:32 PM
3000GTPHREAK's Avatar
3000GTPHREAK 3000GTPHREAK is offline
Banned
That is actually happening to my car right now and no, the thermostat is not the problem (I realise after wasting my money on a new one.) It's simply that while you idle and aren't moving, obviously there is no cool air cooling down the coolant in your radiator... it's doing opposite from the engine heat. I know it sux, but unless you wanna change out the whole system, just don't sit and idle forever... It wastes gas too!
Old 06-14-2004, 05:42 PM
youngvr4's Avatar
STREET RACING GURU
yeah that was my idea also, thanks buddy
Old 06-15-2004, 10:41 AM
LOL!
