Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 06-08-2004, 04:16 PM
jimbob338 jimbob338 is offline
Trouble replacing front speakers in 2002 malibu.
I have instructions from Crutchfield on how to replace speakers.
My problem is the last step in the instructions. How do you pry
out the door panels? More specifically, how do you pry them
out without scratching up the metal trim around doors?
Any help would be appreciated.
Thank you.
jimbob338.
Old 06-10-2004, 01:17 PM
burly burly is offline
Re: Trouble replacing front speakers in 2002 malibu.
Once I removed the trim piece around the mirror and removed the screws behind the door handle, and removed the window/doorlock controls and door opener trim, I removed the door panel. To do this, I used a piece of 1x4 wood. Use a wide flat blade to get your fingers underneath, and then slide in the piece of wood and then pry out that area's body clip. It will take quite a bit of force, probably around 40lbs, to pop the green body clip out of its mount. If I recall, there are two on the rear facing face of the door, three on the bottom and two on the front facing face of the door. After that, it comes right out.
Car: 2003 Malibu (Base)
Modifications: KC Fog lamps, autodimming rearview mirror w/ compass&temperature, window tinting, rear speakers, front speakers, sub, synthetic ATF & aux tranny cooler.
Future modications: Dynamat interior, alloy wheels & new tires, intake, exhaust & intake manifold???
Old 06-10-2004, 04:34 PM
Cooooooool,
Thanks a lot, burly.
jimbob338.
Old 06-20-2004, 09:01 PM
Cidthefallen Cidthefallen is offline
that problem was irritating me so i just put my foot against door and pulled.. after i was done the glue that we on the panel gave pretty easy and i just put some super glue on em and good as new..
