heat problem
my car keeps heating up to an unsafe level. the temp gauge would raise and my air conditioning would start to heat up. what r the different possibilities of anythin broken?
Had same problem with camero, checked thermostat first, making sure it opened at high temp. When it was fine,it turned out to be that my Radiator Cap was not relieving pressure to the reserve tank.
Re: heat problem
i dont have a manual so where is the thermostat at?
Re: Re: heat problem
Thermostat is in an metal housing that comes from the radiator, a large hose that enters the side of the intake manifold, usually very accessable. |
Re: heat problem
your best bet man would to go and buy a manual, you will get your 20 bucks worth
Re: heat problem
im good. i found it and it had some dirt in it and my car is fixed.
