Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 01-22-2002, 09:37 AM
ky_infiniti2000's Avatar
ky_infiniti2000 ky_infiniti2000 is offline
Send a message via ICQ to ky_infiniti2000 Send a message via AIM to ky_infiniti2000
Roller Rocker rumors
I have heard rumors of a roller rocker setup under development. Does anyone know the status of this setup?
Old 01-22-2002, 10:07 AM
gdalton's Avatar
gdalton gdalton is offline
Are you talking about a roller rocker engine because the 2k+ models have these, or are you talking about cams for the roller rocker engines in which case I have heard that JWT is still working on the R&D for that.
05 Big Blue Stepside
“Somebody kicked my dog Mavis and I’m going to find out just who the hell it was. I’m all messed up on cough syrup right now so just like nevermind.”
Old 01-22-2002, 10:09 AM
I am talking about a roller rocker setup for earlier sr20de's.
Old 01-22-2002, 11:30 AM
gdalton's Avatar
I have no idea but maybe some one else will.
Old 01-22-2002, 03:02 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
I haven't heard of anything... but if you are really looking into it, i'm sure you could buy a newer motor and swap it in, if you wanted the roller rockers, but i'm not sure it would be cost effective. You could most likely spend your money on a different mod and gain more power and torque (what the rollers are really supposed to help with, i thought) than the swap, for quite a bit less money.
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 01-22-2002, 05:52 PM
2002G20Racer's Avatar
2002G20Racer 2002G20Racer is offline
What exactly do the roller rockers do anyways?
Anyone who tells you money is the root of all evil, doesnt f#!@ing have any.
Old 01-22-2002, 08:59 PM
JustinP10's Avatar
hopefully i don't screw this up....
The roller rocker motors are basically just a motor with different rocker arms, lifters, and cams (right?) instead of a conventional rocker arm, like the older sr20's had, the newer motors have rockers arms with a "roller" on them that contacts the cam, and has less friction, cause the roller will roll against the cam rather than use oil to lubricate the two parts. Supposed to free up a little bit of power by the reduction of friction in the motor?
Justin McClanahan
95 G20
Old 01-22-2002, 09:46 PM
I can see how that works.
Old 02-05-2002, 08:25 AM
TeamNissan TeamNissan is offline
Send a message via ICQ to TeamNissan Send a message via MSN to TeamNissan
I have heard that the roller rockers are not able to take as high rpm as normal rockers.
Is that correct!?
NISSAN RULES...........
http://www.nissanklubben.dk
Old 02-05-2002, 08:40 AM
T4 Primera T4 Primera is offline
Speculation:
That could be due to the added inertia of the extra mass of the roller rockers themselves. The extra momentum of the extra rocker mass might be enough to overpower the valve springs at high rpm (which would mean that the roller loses contact with the cam lobe on the closing ramp before crashing back down on the lobe). Stronger valve springs might help - but then they may also add to the inertia.
"The cause of liberty becomes a mockery if the price to be paid is the
wholesale destruction of those who are to enjoy liberty."
-- Mohandas Karamchand Gandhi
"They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin
"The biggest cause of trouble in the world today is that the stupid people are
so sure about things and the intelligent folks are so full of doubts."
-- Bertrand Russell
Old 02-05-2002, 08:57 AM
Hey pal,
Thanx for the info! Then I got that straightened out!!
