Old 06-08-2004, 03:51 AM
mghntnfsh mghntnfsh is offline
Angry warped rotors
I own a 98 Z71 with 160k and a 99 Suburban with 50k. Since these are the 4th and 5th of this type GM trucks, I know that these things eat front brake pads. I recently did front brake jobs on both of these, turning the rotors and new semi-metalic pads from my local auto parts store. My problem is that before either of these vehicles had a 1000 miles all 4 rotors were warped. Now looks like $35.00 a throw for rotors, but I'm not sure what pads to use. I have used these same pads in the past only getting about 25k out of them but not warping. Any advice would be greatly appreciated.
Old 06-08-2004, 05:00 AM
Mork Mork is offline
Re: warped rotors
Go buy quality rotors. I found that cheap brake rotors will not last pissing time. I have replaced many brake rotors and pads and have yet to get satisfactory performance out of cheap rotors. The last set I installed was on my wifes saturn in 2001. I got 3 months out of them before they warped so bad she couldn't drive it. I spent the extra cash on a high quality pair and they have been on for this past 3 years. Nopt a problem with them at all. Well worth the extra cash.
Old 06-08-2004, 12:11 PM
Jimmiz71's Avatar
Jimmiz71 Jimmiz71 is offline
Re: warped rotors
I agree $35 sounds way too cheap.
for my truck they run from $90ea.- $170 Go with the better Rotor it will make a big difference.
-Jimmy
~99' Silverado z71 LS 5.3~
Alpine CDA-9830 Head Unit
2-JLW12 Subs
Infinity Surrounds
Too Many Extras
04' Yamaha YZF R6 Super Sport~
Liquid Silver with Black Ghost flames
K&N Filter, Fender Delete Kit
Aftermarket Mirror Shield
Devil Carbon Fiber High Mount Pipe
Power Commander III
02' Subaru WRX Turbo Sport Wagon
Eibach Springs, Short Throw Shifter
17" Versus Campionato Wheels Wrapped in Pirrelli tires
Old 06-08-2004, 09:57 PM
killerkatana75's Avatar
killerkatana75 killerkatana75 is offline
Hey man the problem might have been that your rotors were below the minimum thicknes specs, before you had them turned. I f so the they would have warped really easily, i used to work at a Meineke Muffler shop, so i have done alot of brakes, the best pads that dont cost way to much, is raybestos ceramic, they wont create dust or squeak. Raybestos also makes rotors to, and trust me, cheap rotors will give you more problems.
Oh yeah, make sure that if anyone takes their rotors to a local shop to be turned , you also have them check the thickness specs on them, to thin of a rotorr could cause it to crack during braking
Old 06-09-2004, 02:38 PM
vnotaro vnotaro is offline
High quality rotors are a must! Classic case of you get what you pay for. However, here's 2 more cents on the subject. Everytime you put the wheels back on, make sure you torque the lugs down to factory specs! Just about every garage that does brake jobs or anything that requires removing the wheels uses an impact wrench to take the lugs off and put them back on. Almost every time unless they are using torque sticks, they put them back on too tight. Also, the torque for each lug will be different. This can contribute greatly to a warping problem for the rotors. If you don't have one, invest in a decent 1/2 inch drive torque wrench. Money well spent and your rotors will last even longer!
