Go Back   Automotive Forums Car Chat > Honda > Integra
Old 06-08-2004, 02:05 AM
kpsycho's Avatar
kpsycho kpsycho is offline
boosting auto ?'s
ok well im gonna boost the auto (no i dont care about your .02 if it has to do with the change to 5spd or trade for a 5spd blahblahblahblah IM BOOSTING THE AUTO!!!) and will be doing a .4 bar (5.5 psi) daily and .6 bar (8 psi) track setting. i will be basicly using a kit like setup something pretty simple for the low boost. although i may go a little higher depends....
basicly what would you do to the auto to handle the boost say i wanted a 7psi daily and 11psi track setup what would you recomend what about the other setup? im thinking just using the levelten.com torque converter setup and a tranny cooler do you think the auto could handle a 7psi daily 11psi track setup or just stick with the 5.5psi 8psi setup?????
Old 06-08-2004, 11:40 PM
kpsycho's Avatar
Re: boosting auto ?'s
hellooooooooo cmon guys at least some opinions on what you think it can handle??? something.
Old 06-08-2004, 11:56 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
it can handle it...an auto can handle more hp than a manual.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 06-08-2004, 11:57 PM
kpsycho's Avatar
the torque converter is rated to 200hp
Old 06-09-2004, 11:47 AM
Crippy's Avatar
Crippy Crippy is offline
your signature sounds very homosexual ....
2001 GSR ,
94 jdm b18c sir-g swap , i/e !!
Old 06-09-2004, 12:24 PM
tsugsr tsugsr is offline
LMFAO!!!!!!!!!! thats great stuff Crippy
Old 06-09-2004, 01:50 PM
YellowITR479 YellowITR479 is offline
what kind of car do you have......auto turbo cars are cool because you dont loose boost inbetween shifts
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 06-09-2004, 04:23 PM
kpsycho's Avatar
well maybe it is!!!.............um ok no its not i was bored and couldnt think of anything. dont have time to make a new one but i will eventually.
i have a 92 integra gs. im in an integra forum go figure it would be an integra. im thinking if i went for the TC and tranny cooler it could hold the higher boost setup.
Old 06-25-2004, 10:42 PM
DSMer4g63 DSMer4g63 is offline
Re: Re: boosting auto ?'s
thats right...a turbo auto will not have turbo lag like a manual...as for the trans maybe a rebuild or like said the torque C....
