Old 06-08-2004, 01:11 AM
48MPGCRXHF 48MPGCRXHF is offline
Engine doesent hold the car
Is it normal for when the car is in gear for it to roll. All the standard cars and trucks i've seen you can put them in gear and they will hold themselfs, are hondas differant? my 89 HF will roll away in first or reverse.
Old 06-08-2004, 01:46 AM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Re: Engine doesent hold the car
Cause your compression is crap. Your HF did not have much to begin with and all the miles it probly has on it has worn the ring allowing air to pass by. Then you get a motor that will trun easy and in gear it will spin.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 06-08-2004, 03:26 AM
91lxdreamer's Avatar
91lxdreamer 91lxdreamer is offline
Send a message via AIM to 91lxdreamer
If I let my car run, and ease the clutch out while its in gear, it rolls...is that normal?
Just jokin man, listen to the above statement, I just had to toss my in
Official AF Primer Crew!
Updated 1-23-05
For sale: Stock 4-door corner lights. 13" stock wheels with 6 month old tires.
Old 06-08-2004, 08:00 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
run a compression test... and check your clutch.
Old 06-08-2004, 08:03 AM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Mines used to do that but I changed my rear brakes and now it stays parked. With the car in second (I never put it in first) and emergency brake up, it doesn't roll anymore. I say make sure your shoes are replaced or adjusted.
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
Old 06-08-2004, 08:09 AM
Forunn Daberator
if the ebrake is on it shouldnt roll weither its in gear or not
Old 06-08-2004, 09:56 AM
Yeah it has 183,000 on it, I was just wondering if they did when they were new. Or if this was normal.
Old 06-08-2004, 10:57 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Question Re: Engine doesent hold the car
I park my car in first gear and it holds it 98% of the time. My rear brakes need to be replaced, so I tend to not use my e-brake unless I have to (park on an unusually steep hill and the engine isn't enough to hold by itself.)
What condition is your clutch in ? When you let out the clutch pedal, can you feel the engine turning (or open the hood and see it)?
Once you've confirmed whether or not the engine itself is spinning with the car, maybe we can keep guessing. If the compression is so poor on the car that it moves in 1st or reverse, I'd be surprised that it runs at all...or that you'd still get 48MPG
BTW - Even tho some of us are smart-asses we always like new people. Welcome to the forum
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 06-08-2004, 02:03 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
I also think you're engine's compression doesn't provide enough resistance to hold the car.
Flunky
Old 06-08-2004, 07:42 PM
Yeah im sure that the engines turning. Cause the car moves with the engine, you know it moves fast till it gets on a compression stroke then it goes slow then fast after the compression leaks off.
