Old 06-08-2004, 12:59 AM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Crank Pulley bolt help!!!!
i am trying to take off the Crank Pulley bolt so i can take block to machine shop to get it honed and hot tanked and have crank turn 10-10 so if someone knows an easy way get the bolt off pleas tell me i took a impact wrench to it and did not budge it please respond asap...thanks
Old 06-08-2004, 04:55 AM
itechengineers itechengineers is offline
Send a message via Skype™ to itechengineers
Re: Crank Pulley bolt help!!!!
an impact wrench.... = hammer it... jump on it if you can, or put your foot on it and grab the frame of the car and torque-loose the bolt...
got a friend with an air compressor?
block the trannie/jam the flywheel and slip a 6ft + pipe on the wrench it will help as a breaker bar...
good luck.
Old 06-08-2004, 05:06 AM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
I've also heard of people pulling a spark plug & filling the combustion chamber with rope to stop the piston from moving while you're cranking on the bolt.
Never personally tried it, but it sounds like it would work pretty well...
Old 06-08-2004, 06:44 AM
src21k src21k is offline
if you can find it there is a tool that pretty much is a vise grip with a chain buit on to it. you lock it onto the crank pully and it holds it in place while you user a breaker bar to loosen it with.
Old 06-08-2004, 11:38 AM
spongerlbc's Avatar
spongerlbc spongerlbc is offline
Send a message via AIM to spongerlbc
Jam a socket in the flywheel then use a 6 foot pipe on a 2 foot breaker bar. Works for me everytime and I'm far from a muscular guy.
DOHC ZC 89 DX HATCH
Old 06-08-2004, 02:00 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
I tried all of the non-power methods, including the 6-foot cheater bar, blocking the wheels, having my girlfriend hold the brake pedal down, and burning incense.
I got my neighbor to bring over his 150 PSI compressor and impact driver, and wwwwwooooden! It was off of there in 2 seconds.
Flunky
Old 06-08-2004, 08:58 PM
ya i ahve a 90 pound compressor and deff not doing the job i was told to get like a 300 or 400 and thing fly right off without holding it down thanks for the info guys....but ya i tried a 8ft bar and wrench and no budge i think its just well put on....
Old 06-08-2004, 09:11 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
You need a good impact, mine has yet to meet it's match...
Old 06-08-2004, 10:38 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
i had to up my compressors pressure to like 130 instead of the stock 90
Team Lonely Drivers
