Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 06-07-2004, 11:38 PM
Ziggymidget5 Ziggymidget5 is offline
Send a message via AIM to Ziggymidget5
Wiring through the firewall on 4th gen
I need to get some wires and a switch through the firewall on my 4th gen Si, and I was wondering if there was a pre-made hole that would work nicely or a trick to drilling through the firewall that I don't know. Right now, it seems like something I don't wanna mess with unless you guys have some tips. And no, it is not for some LED Washers, it's for some driving/fog lights I'm thinking of getting. Thanks for any help.
White 1995 Prelude Si 5-speed 107,000 miles
AEM CAI
AEM Pulleys
DC Sports CC Header
Carsound Hi-flow Cat
5Zigen Fireball Cat-back
17" wheels with 215/40/17 tires
Custom paint on some interior (yellow)
Currently in Progress:
KMS (Honda-performance.com) Camshafts, Valve springs, and Retainers
Skunk2 adjustable cam gears
Wish me luck on this project, something always seems to go wrong.
My 1995 Prelude Si
Old 06-08-2004, 11:58 AM
Sk8erprelude Sk8erprelude is offline
Re: Wiring through the firewall on 4th gen
You should have a hole with a plug in it on the passenger side on the firewall. If you look, the plug is made of plastic/rubber and can be removed with your fingers.
Old 06-09-2004, 12:29 AM
OK, thanks. I will check that out tomorrow probably.
AEM CAI
AEM Pulleys
DC Sports CC Header
My 1995 Prelude Si
Old 06-09-2004, 05:31 PM
weezer21403 weezer21403 is offline
good luck i tried to fnd that hole and never did then i tried to drill through and that wasn't very easy either
Old 06-09-2004, 05:33 PM
dbebesi's Avatar
dbebesi dbebesi is offline
that plug is really hard to pull out, just push it through with a screwdriver, and it falls right on the floor of the passenger side.
Old 06-13-2004, 03:27 PM
I tried to find this plug from both the inside and outside, but I couldn't. Does anyone have any pictures for this or a page number to find it in the Helm's manual?
AEM CAI
AEM Pulleys
DC Sports CC Header
My 1995 Prelude Si
Old 06-14-2004, 08:49 AM
Hey ziggymidget5 what is your email? I will send you pictures of the plugs tonight to your email address, don't know how to post pics on forum. There is 2 on my car on passenger side by fuel charcoal canister engine area.
Old 06-14-2004, 10:42 AM
My E-mail is [email protected]. Thanks for your help.
AEM CAI
AEM Pulleys
DC Sports CC Header
My 1995 Prelude Si
Old 06-14-2004, 10:52 AM
grumblemarc grumblemarc is offline
Send a message via Yahoo to grumblemarc
Unbolt your fuse box and move it to the side. You can see a "plug". This where I just cust a slit in it and fed the wires through when I wired up my amp. You can even run wires through the same grommet the fusebox is using. Just cut a slit in it but be very careful when doing so as you don't want to cut into other wires.
Old 06-14-2004, 06:14 PM
Check your email. Pics sent.
Old 06-14-2004, 09:00 PM
Thanks for all the help. I took off the fuse box tonight and found atleast one of the useable plugs and where it leads to. From here on out it should be simple.
AEM CAI
AEM Pulleys
DC Sports CC Header
My 1995 Prelude Si
