Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 06-07-2004, 11:18 PM
wellhung2004's Avatar
wellhung2004 wellhung2004 is offline
Send a message via AIM to wellhung2004
why is this?
my 89 240 cuts out when i give it gas promptly, its auto, and it dies if i dont give it some gas right when it starts up? what in the hell?
http://store3.yimg.com/I/jspec_1793_10301627
Old 06-08-2004, 12:02 AM
J_Spec_NiTeMaRe's Avatar
J_Spec_NiTeMaRe J_Spec_NiTeMaRe is offline
Send a message via AIM to J_Spec_NiTeMaRe
Time for the typical high-mileage 240 tuneup.
-Replace fuel filter with one from a 300zxTT
-Service AIV Valve, EGR Valve, MAFS, TPS, Coolant Temp Sensor
-Inspect all vaccum lines for cracks, leaks, misconfiguration, replace any needed
-SEAFOAM
-NGK Spark Plugs
-02 sensor
I've owned three 240s now, a S14 and two S13s. My thrid one was horrific...I was lucky to make it back to my house. It stalled out every time I let off the gas, it had a terrible warm start problem, and so on. I did those six things and it ran like absolute new. Perfect acceleration, smooth decel, no popping, purring idle, everything. Good luck.
Old 06-08-2004, 03:13 PM
publicenemy137's Avatar
publicenemy137 publicenemy137 is offline
Send a message via MSN to publicenemy137
Re: why is this?
hey j spec nightmare are bosch platinum spark plugs good??? I wanted to get NGKs but they were $10 a piece, the bosch's were $2 bux so I don't think it will make that much of a diff.
Old 06-08-2004, 05:22 PM
NGK are most definitley worth it. If they were 50$ for the set, they would be worth it. They kick the living shit out of the Bosch's. That engine is designed to work with NGKs.
Old 06-08-2004, 05:28 PM
logik23's Avatar
logik23 logik23 is offline
Banned
Send a message via MSN to logik23
I usually don't go by the price to determine if something is good or not, but 5 times the price rpobably means they're at least a little better. ;-)
Old 06-08-2004, 11:09 PM
Re: why is this?
hmm... Maybe i'll take my bosch's out and put down the $40 for the NGKs then
Old 06-09-2004, 12:02 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Re: why is this?
on a n/a motor copper plugs arnt necessary b/c they do not require a colder spark.. platinum plugs will be the best bang for the buck.. but i agree that bosch sucks ass.. but $10 for ngk is a rip off i paid 10.55 for my set of four ngk v-powers.. they usuall ratail for about !.50 tp 2.20 each with copper plugs.. for $10 a plug you might as well pay a little more and get denso iridum.. look on line they are cheap as hell there
1
Shift_BOOST
97 s14
