Old 06-07-2004, 10:56 PM
Kats Euro Kats Euro is offline
Send a message via Yahoo to Kats Euro
Angry Cooling Fans will not turn on unless hardwired.
I have a 90 lumina euro 3.1. The other day my temp gauge went sky rocket. One of my friends came over and checked it out. Neither one of my cooling fans will kick on when the temp raises to where they should be on. We checked the fuses and they all look good. Is there something else we can check. When we took the fuses out and took a wire and hard wired them. They ran. But when you would turn the car off it would stay running till you removed the wire. Is there some sensors that I could check or anything else. If some one knows where on the motor I could check it would really be appreciated. Thanks
Old 06-07-2004, 11:57 PM
chevysrule chevysrule is offline
Re: Cooling Fans will not turn on unless hardwired.
hey i have a 1990 lumina euro 3.1 also and im having the excact same problem but only with one of my fans. geez
Old 06-08-2004, 12:12 AM
chevysrule let me know
If you figure out what is wrong with your chevy let me know. I really need to get this fixed. Especially in this hot weather. I can not be with out a car. For my hubby is using my 99. Thanks
Old 06-08-2004, 03:23 AM
sysopt sysopt is offline
The engine coolant temp sensor may be bad. The fan relay might be bad. The wiring might be bad also. Youve ruled out the fan itself. That covers most of it.
Old 06-08-2004, 11:50 AM
overheating
i find it very annoying as it only happens once inawhile. i bought my car in novemeber and the thing never overheated until it started to get warm out. I need to fiqure out whats wrong with it as my man is too busy fixing his new car to worry about myn, but now im making him drive my lumina maybe then he will realize it overheats when it happens to hime and he can finally fix it! i was thinking maybe the thermostat was sticking but not to sure!
Old 09-19-2004, 09:54 PM
Gary Magby Gary Magby is offline
Send a message via MSN to Gary Magby Send a message via Yahoo to Gary Magby
Re: Re: Cooling Fans will not turn on unless hardwired.
where is this sensor????
Old 09-19-2004, 10:42 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Relay. Sensor. One or the other.
Old 09-19-2004, 10:44 PM
If you disconnect the sensor, and ground the wire to the engine, the fan should start. If not, sensor might be the problem.
Old 09-19-2004, 10:45 PM
Keep overheating that 3.1 and nobody's gonna be driving it soon....
Old 09-19-2004, 10:48 PM
I think there is two sensors for coolant temp-one for the ECM and one for the gauge/light. The ECM one is suspect, since your gauge is working.
Old 09-20-2004, 12:46 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
the fan sensor is on the drivers side of the motor, just below and to the rear of the car from the t-stat housing. The relay is in the relay center under the hood just behind the passenger side headlamp. They are both cheap enough, so replace both and unless you have a broken wire, it should fix your problem. There are two relays, one for the A/C fan, the other for the main fan.
