Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 06-07-2004, 08:03 PM
Old Yeller Old Yeller is offline
Angry 2004 Transmision Problems
Hi All,
I have a 2004 1500 4x4 with the 5.7L. I'm still getting a nasty clunking sound when going from drive to neutral, and reverse to park. Dealer says that it's just play in the tranny. Anyone have any suggestions on a resolution to the problem, or is it really normal.
Old 06-10-2004, 01:33 AM
calgary_redneck calgary_redneck is offline
Re: 2004 Transmision Problems
sounds like to much back lash in the rear end between the ring and pinion
Old 06-10-2004, 07:15 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
There's a body wrapped around the driveshaft. Take his belt off and the clunk will stop.
I don't know. This is the second time I've heard this and both the reasons were that it's "normal".
I'd worry about it when the truck stops being able to move itself. If it's not causing a problem, why worry about it?
Old 06-25-2004, 09:46 PM
LTJGWorth's Avatar
LTJGWorth LTJGWorth is offline
If its a 2004 why not take it back to the dealership and have it fixed. You can't tell me your warranty is up already!?!?
Old 06-26-2004, 02:47 AM
BleedDodge's Avatar
The dealer won't fix it because he said the dealer said it was normal.
My Mopars
Old 06-29-2004, 01:02 PM
dirty dan dirty dan is offline
Have you checked your U-Joints?
Old 07-02-2004, 03:56 PM
dirttraker dirttraker is offline
I have a '03 2500 w/Hemi 41000m. I have had the valve body replaced and both u-joints on main driveshaft.
Old 07-11-2004, 05:07 PM
hemipower hemipower is offline
It really does sound like a U-joint. My '03 2500 hemi 4x4 has had the rear u-joint in pieces at about 38,000 miles. It is at 55,000 now and it needs the front one done before scatter.
