Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 06-07-2004, 07:38 PM
bluegoat bluegoat is offline
abs brake problem?
1993 Jeep Grand Cherokee Limited, 4wd, 4.0.
Brakes work good as far as stopping is concernd, however, when I am almost stopped, just before I stop, the pedal depresses a little bit, shimmys, then catches. A funny feeling, like its going to go to floor but never does.
I replaced the front rotors and pads, no change. I do not have the death wobble as has been described here, this is in the pedal itself, but just briefly. The rear drums are in good shape, no leaks. The pedal does not slowly go down with a steady pressure if it would be. Like I said I have good brakes other than the weird feeling right before a stop.
Took it to a Jeep dealer, they spent two hours looking and said everything checks out o.k., they called "Star", I guess the makers of the abs for jeep. They said the ECU was bad, 520.00. I said no and got one from a yard for 40.00. Same problem, no change. Any ideas guys. Please help, goin on a trip in a month, don't want brake problems on the road. Thanks. Oh, no brake light comes on, like I said everything is good except the glitch right before it stops.
Old 06-08-2004, 05:54 PM
Re: abs brake problem?
Anybody? Guess?, not even a remark from dsilver?
Old 06-11-2004, 09:24 PM
tdenkler tdenkler is offline
similar prob
had similar on my 93, but brake light did come on. fluid didn't look that low, but added fluid and leveled both brake fluid holders. light went out and prob didn't return. yet! @ 2 months
Old 06-12-2004, 08:11 AM
98cam 98cam is offline
Re: similar prob
Sounds like the brake booster going south....try this check straight from the manual.
1 Depress the brake pedal several times with the engine off and make sure there is no change in the pedal reserve distance.
2 Depress the pedal and start the engine. If the pedal goes down slightly, operation is normal.
Try bleeding the brakes and check your pedal travel sensor located on the booster.
(mine)Red 94GC LTD, 5.2, lifted. (hers)Light khaki 03 (2wd) sport Liberty.
Old 11-04-2013, 07:14 PM
HonokaaHi HonokaaHi is offline
Had nearly same symptoms,Turned out to be ABS speed sensor on left rear wheel. I suppose
any of the four would have caused same symptom
Old 04-17-2014, 11:39 PM
Thomas Sams Thomas Sams is offline
Banned
You have adjustable drum type brakes on the rear wheels or you adjust himself or may be speed sensor of the wheel is dirty that's why this problem is created i was face the problem of these types..
