Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 06-07-2004, 07:29 PM
DENPOGI DENPOGI is offline
Send a message via AIM to DENPOGI Send a message via Yahoo to DENPOGI
How To Change The Battery On 2000 Intrepid
I will be changing the battery on my 2000 intrepid very soon. Can anybody tell me where the battery is located and a step by step procedure on how to change this. Thank you very much.
Old 06-09-2004, 02:08 AM
indyram indyram is offline
Re: How To Change The Battery On 2000 Intrepid
look under the hood. take off the bracket holding it in place. take off positive and negative cables. pull out battery. installation is reverse.
Old 06-09-2004, 03:03 PM
Thank you very much but that is my problem, I can't find the battery under the hood. Any idea where the batterry is located? thanks again
Old 06-11-2004, 08:48 PM
Borgon Borgon is offline
Here is what my owners manual says:
The Battery is stored in a compartment in front of the tire in the right front fender and is accessible through the engine compartment. The tire and wheel need not be removed to access the battery.
To access the battery:
1 Turn the sterring wheel fully to the right.
2 Remove the battery access panel form the inner fender shield.
3 Remove the air cleaner.
4 Move the battery into the opening and lift it out.
I have not done this but have seen the inner panel.
Good luck.
Old 06-12-2004, 06:52 PM
2crunk's Avatar
2crunk 2crunk is offline
When i changed mine, changed twice, when i bought it, i changed the battery thru the fender well, the second time, disconnected the air breather and lifted up thru the top, the second choice is what i reccomend.
