Old 06-07-2004, 07:23 PM
geofroley geofroley is offline
Send a message via AIM to geofroley
Metal flakes for paint
Where can I find metal flakes to add to paint? Also how would I mix it in?
Old 06-07-2004, 07:26 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Metal flakes for paint
Metal flakes are made by different automotive brands, such as HoK and PPG. Then get some PPG (or HoK) paint (depending on the flake) and mix the PPG (or HoK) flakes into the PPG (or HoK) paint. Just dont cross mix the paints.
Have you ever airbrushed automotive paints?
-Mike
Old 06-07-2004, 07:37 PM
Don't quite have an airbrush yet. I'm going to wait to buy it until my dad comes back from his honeymoon.
Old 06-07-2004, 07:44 PM
mike@af's Avatar
Flakes are tricky to spray, but not as tricky for small things. Make sure your airbrush is not for fine spraying otherwise the flakes will clog up. I suggest pearls for models as well, they look more like scale flakes. Flakes are huge on models and can make or break a model.
-Mike
Old 06-07-2004, 08:28 PM
Thanks for all the help GTMike. Does this mean I can't mix the flakes with regular hobby paint?
Old 06-07-2004, 09:50 PM
ZoomZoomMX-5's Avatar
Craft store chains Hobby Lobby and Michael's carry a line of pearl pigments that can be added to hobby paint for a pearl/metalflake appearance. These pigments are found in the rubber stamp dept. There are two sets of different colors. You mix the flakes (just a small amount) into premixed clear or translucent paint, it doesn't work well w/solid colors...you want pearl over a solid color, not in it. The two sets aren't cheap, but you can watch for sales. Black Gold also sells pearl pigments. If your airbrush will spray pearl or metallic paint, it will spray your homemade concoction just as easily. All you are doing is adding the pearl pigment yourself.
For best results, layer the pearl coat over the color coat, then cover the pearl coat w/clear. It's pretty simple w/an airbrush after just a bit of practice. Remember that a small amount of the pigment goes a LONG way-the little containers of pearl pigment will last you forever if you use it sparingly. For most bodies, you won't need much clear/pearl for the effect, I'd start w/no more than a grain of rice sized amount of pearl pigment added to the clear. Practice on something before attacking a prized project.
My Fotki Album
Old 06-07-2004, 10:03 PM
mike@af's Avatar
No problem, ZoomZoom pretty much sumed it up. I wouldnt cross breed auto flakes/pearls with hobby stuff. I would cross breed anything, but thats just me.
-Mike
Old 06-07-2004, 10:20 PM
Inservible's Avatar
Inservible Inservible is offline
Send a message via ICQ to Inservible Send a message via MSN to Inservible Send a message via Yahoo to Inservible
If you go to the craft store, you can buy some acrylic paint and acrylic medium, if you add 3 parts of solid color paint, 2 parts of acrylic medium and 1,5 parts of pearl pigments (1,5 rice grain approximately), you will make yourself with a very realistic metallic paints, first of all you have to make the solid color, but keep in mind that the final color will be slightly clear than the one you are watching before spraying it.
The acrylic medium is used to make a translucent color from the solid color, but it makes slower the drying process.
Mark
Current Project:
'57 Chevy Bel-Air
'55 Mercedes 300SL "Gull wing"
Old 06-07-2004, 10:36 PM
proosen's Avatar
proosen proosen is offline
There was an article in SAE some time ago about this, check it out. http://www.scaleautomag.com/sca/default.aspx?c=a&id=43
Niclas
Old 06-07-2004, 10:37 PM
jdmhotrod's Avatar
jdmhotrod jdmhotrod is offline
Banned
pegusus hobbies makes metalflakes you can add to clear cote.
Old 06-08-2004, 03:41 PM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
House of Kolors sells ultra mini flake that is a good scale match for models.
Old 06-08-2004, 03:44 PM
Re: Re: Metal flakes for paint
Sweet. So lets see if I got this down. I can't use metal flakes with hobby paint, only automotive paint. Am I right on this?
Old 06-08-2004, 03:47 PM
dag65's Avatar
Re: Re: Re: Metal flakes for paint
Doesn't really matter, they are dry flakes which can be added to tamiya or testors clear and airbrushed just as easily
Old 06-08-2004, 08:18 PM
Re: Re: Re: Re: Metal flakes for paint
Nice. Should I use HoK flakes or Pegasus flakes?
Old 06-08-2004, 08:59 PM
mike@af's Avatar
Re: Re: Re: Re: Re: Metal flakes for paint
Probably pegasus. The flakes I use from HoK cost about $26.50USD, I dont use them to paint models either.
-Mike
