Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 06-07-2004, 08:06 PM
Fibreglass Junkie Fibreglass Junkie is offline
Send a message via MSN to Fibreglass Junkie
Help I Need Wheel Spacers!!
I Have a 99 civic coupe and just aquired a set of 19" rims all good. they look awesome! but I can only get half lock on my steering before they catch on the inner arch. Anyone know where I can get some longer wheel bolts and spacers from so the wheels come out to the edge of my widearch kit?
Old 06-07-2004, 08:11 PM
96Civic_Coupe 96Civic_Coupe is offline
Banned
Re: Help I Need Wheel Spacers!!
wheels spacers are not safe.
Old 06-07-2004, 08:47 PM
Any other ideas then? Bigger/Smaller offset?
Old 06-07-2004, 09:48 PM
loesch8102's Avatar
loesch8102 loesch8102 is offline
Send a message via AIM to loesch8102
19's are just too big for a Civic. If you must, you will most likely also need to modify the fenders. It's just too big of a pain, plus in my opinion it looks rediculous.
Old 06-07-2004, 10:21 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
You can use spacers up to a point. I recommend 7-8 full turns of your lugs for proper engagement. Anything less and you could work the lugs loose = BAD!
I use a 3mm spacer for some of my wheels. Just make sure you check the torque on your lugs once in awhile.
Also you will not pass inspection using spacers.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 06-08-2004, 11:57 AM
BlackCiv00 BlackCiv00 is offline
i have 18x7.5 on my 2000 Civic EX and the rear tends to rub the inner part of my wheel well when i hit small potholes/hills on the road....im from NY, so the roads are shitty. they dont rub all the time, but they rub the most when i have weight/people in the back. i no longer ride anyone in my car except for the passanger that sits in the front. i see you guys talking bout spacers, and have one question, would i need spacers on all four wheels, or can i just get a pari for the rear?? also, anyone have any recommendations on which spacers to buy, or does it even matter? i know they come in different sizes, so what size would one recommemd for me??...i dont want the tires to stick out too much either. hopa ya can help.
Old 06-08-2004, 12:00 PM
19's fit on the front with only a quarter turn lost and the rear loves them. The fenders did have to be rolled but that is little problem. I need an extra inch of arch fillage though! If I cant use spacers what can I do?
Old 06-08-2004, 02:28 PM
Civic Mod
Re: Re: Help I Need Wheel Spacers!!
They do come in different sizes. I run 3mm spacers since my 15x7" 45mm offset wheels were hitting the rear upper control arm. Now I have 38mm offset and the tires are now hitting the fenderliners.
You would prolly want 1-2mm spacers - that's about all you could prolly use.
Mike
Autocross Help Page
Buy my Civic parts!
Old 06-19-2004, 02:53 PM
Right I may be able to get some wheels that are custom fit. Does the hub move toward the outside or inside as the offset figure increases??
Old 06-20-2004, 10:40 PM
Civic Mod
Higher number wheels more under the fenders. Lower number the wheels move outwards.
Autocross Help Page
Buy my Civic parts!
