Old 06-07-2004, 05:53 PM
AmatureCDV Driver AmatureCDV Driver is offline
Send a message via AIM to AmatureCDV Driver
door!!
OK, so i am trying to take my inner door panel apart, but i cant get the handle for the window off. I dont wanna just pull it and have it break off. Is there a screw or something holding it in or should i just pull it off??any insites of advice is appriciated! thanks
Old 06-07-2004, 09:10 PM
bigrod118's Avatar
bigrod118 bigrod118 is offline
Re: door!!
yeah, haynes manual will show you a picture to better explain, but ill try. theres a sorta U shaped pin in there, that holds the crank on, just take a flathead screwdriver and shove it under the crank, from the handle towards the base of it, right where the handle comes off the base, ts really hard to explain. but there is a samll pin under there holding it on, but the haynes maunal will show you a picture and its just a good thing to have anyway, 10 maybe 15 dollars at autozone or pep boys or whatever.
Old 06-07-2004, 11:11 PM
Re: Re: door!!
thanks a lot for the help. I will give it a try in the morning.
