Old 06-07-2004, 05:03 PM
Chief_Cherokee Chief_Cherokee is offline
I am in need of a little bit of help !!!!!!
Hello. I know this is a long one but i am in need of help so i would really appreciate it if you could take the time to read through this one! I have recently been having some problems with my 1996 Jeep Cherokee Sport. It has the 4.0 Litre, High Output, In-Line 6 engine (Fuel Injection). We have taken it to the shop 3 or 4 times already now and they are even stumped by this one. Sometimes it will start normally and other times it won't. When it won't start, it turns over, but it just won't start up. Other times it will turn over and begin to run for a split second then it will hesitate or sputter and it won't start again. Sometimes when you start it, it hesitates, like it isn't getting enough gas or something but then it runs normal after a few seconds. It seems to take longer to start it recently as well (You have hold the key in the ignition longer so that the starter motor is going and then it will start, but you never had to do this before). Other times it will start somewhat alright, but then when you turn it off and try it again it won't start anymore. When it won't start, you have to depress the accelerator to the floor to get it started. The second problem is that when it is idling it will sometimes idle higher than normal. Also if you depress the accelerator a little bit and let it off right away, the engine won't rev down right away. It is like your foot is still on the accelerator. After a few seconds it will start to rev down. It does the same thing when you are driving. If you let off the accelerator the revs do not come down right away. It is like something is getting stuck. There has been a brand new (Jeep) distributor put in, and the idle control arm has been cleaned. When it is put on the scope, it shows that nothing is wrong, and no codes or anything come up. Can somebody please help me and give me some tips?!?!?!?!?!? Thanks for taking the time to read through this long description. I would really appreciate any help or tips whether they are small or big.
THANKS
JASON
Old 06-07-2004, 05:15 PM
Dale Aeppli Dale Aeppli is offline
Re: I am in need of a little bit of help !!!!!!
THANKS
JASON
HI, IT SOUNDS LIKE THE THROTTLE POSITION SENSOR IS STARTING TO GO IT IS MOUNTED ON THE THROTTLEBODY SHAFT. PROBABLY WOULDN'T HURT TO DUMP SOME GOOD THROTTLEBODY AND INJECTOR TECHTRON IS IN CHEVRON GAS IT WORKS GOOD. HOPE THIS IS OF HELP USUALLY THE THROTTLE POSITION SENSOR WON'T SET A CODE DALE [email protected]
Old 06-07-2004, 08:11 PM
THANKS
JASON
HI I MISSED THE PART ABOUT STARTING YOU COULD HAVE A CRANKSHAFT POSITION SENSOR GOING BAD THEY USUALLY DON'T TRIP A CODE HOPE THIS IS OF HELP DALE [email protected]
Old 06-07-2004, 09:30 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Sounds like a problem I have with mine sometimes... sometimes it won't start, and I have to wiggle the TDC sensor wire to get it to kick over, but alot of other times, when it does start, it idles up to about 2800 RPM and just stays there, and I have to shut it off and restart it several times before it will actually idle normally... Sorry I can't help you with that problem, just thought I would chime in.
