Old 06-07-2004, 03:56 PM
yezek6 yezek6 is offline
engine cutting out
1995 dodge caravan 3.0L
its more noticeable durring steady speeds and durring shift points and durring take off. does anyone have any ideas what this problem is?
Old 06-08-2004, 10:47 AM
fadelu fadelu is offline
Re: engine cutting out
You have to have the error code read before you start doing anything. The speeds are electronicaly controlled. It could be a faulty fuel pump or any component with the air fuel mix
Old 06-08-2004, 11:09 AM
but if there was a error code would the check engine lite come on?
Old 06-09-2004, 12:13 PM
slantsixness's Avatar
slantsixness slantsixness is offline
the check engine light doesn't come on until the ECM is in "limp-home" mode.
Check your ECM codes:
http://www.allpar.com/fix/80s-codes.html
I know it says 80's, but the newer ones are linked there too...and they're not much different.
You may just need a tune up, or the EGR valve is bad. Hard to tell for sure without the codes.
Slantsixness
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
Old 06-09-2004, 07:18 PM
it showed a code 55
Old 06-10-2004, 07:49 AM
55 is normal.
Probably a good tune up and injector cleaning will fix it, or your ignition wires/distributor cap and rotor is/ are bad.
They're cheap enough, just replace them with the tune-up.
If you don't want to spend $ on injector cleaning, then buy a good bottle of cleaner (in the tank) and run a tank of premium through it and see if that helps.
Slantsixness
