Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 06-07-2004, 03:19 PM
chicop chicop is offline
Dash guages madness
I'm a newbie!
I have a 99 Grand AM SE 2.4L and I love it BUT about 2 Months ago I started to have porblems with the Gauges in the dash going OF for a very short time and coming back on right the away usualy when I was starting the car. Also I noticed that my blower does not work at that time.
Lately it's hapening eaven when I drive down the highway and a lot more often and for longer periods of time.
Any help with this I would apreciate verry much.
Thanx.
Old 06-07-2004, 04:17 PM
Rod&Custom's Avatar
Rod&Custom Rod&Custom is offline
Send a message via Yahoo to Rod&Custom
WHOOOAAA!! A blower? You mean fan, right? If you got a blower on a Grand Am, you'd be a REAL sleeper. Too bad they don't make blowers for 'em, just turbos. When the lights shut off like this, does the car die? What all, in detail, shuts down when this happens. Could be something as simple as a loose battery cable. Sounds dumb, but it happens. Hope your lucky and this is the fix.
Old 06-07-2004, 04:29 PM
Hi Rod&Custom
Yes sory the fan. Nothing hapens the car runs fine the only things I noticed so far is that the fan and any of the guages don't work ,it's like the key is out of the ignition compleatly.
I looked for loose conection but so far I could not find any.
Old 06-08-2004, 08:30 PM
Rod&Custom's Avatar
Ahhh, too bad. My '97 Bonnevile just stopped dead one day, lights and all were gone. Checked, and lucky me, it was a loose battery cable. Too bad you couldn't be as lucky, I will keep brainstorming, and if I come up with something, I will tell you ASAP. I know these things can be very annoying.
Old 06-09-2004, 12:09 AM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
Re: Dash guages madness
Had the same problem as rod&custom , loose + connection to the main fuse box under the hood (stupid me didnt tighten it so it rattled away) my car would turn off at 60mph and no light nothin nada cept my underbody lights worked right off the battery so at least I had hazzards lol
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
Old 06-10-2004, 08:25 PM
My car keeps running just fine while I loose power to dash.It just bugs me that I don't know what KM/Hour I'm driving at and I have no fan (a/c)
This might not have anything to do with it but I noticed that sometime it happens shortly after I turn the fan on.
Old 06-10-2004, 09:07 PM
Thats not cool , sounds like an inline fuse link is loose to me. This could be tough to find , have it looked at yet?
Old 07-28-2008, 03:40 PM
brocsbar brocsbar is offline
I had a similar problem with a car I was working on in my shop. All the guages would jump around and after extensive searching I found that the airbag module under the passenger seat was getting wet for years from the bad water problem on many grand am/prix. And after a while the car wouldn't even start cause the module was shorting and the car tought someone was stealing it.It can be disconnected and everything should work normal again except you Won't HAVE AIRBAGS!
Closed Thread
