Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 06-07-2004, 12:21 PM
pepo pepo is offline
Question 1997 Grand Cherokee 4.0, new oxigen sensor and still code 21
I have a 1997 Grand Cherokee Laredo 4.0
The check engine code get the "code 21 oxigen sensor"
I've replace with an universal "the ones with 4 wires, 1 black, 1 purple and 2 whites and you have to solder the original plug on it" I've replaced and the code 21 still.
What I'm doing wrong??
Thanks in advance.
Old 06-07-2004, 02:12 PM
Dale Aeppli Dale Aeppli is offline
Re: 1997 Grand Cherokee 4.0, new oxigen sensor and still code 21
Thanks in advance.
HI TRY DISCONNECTING THE BATTERY GROUND CABLE FOR ABOUT 45 SEC. IF IT DOESN'T OFF REMOVE BATTERY POSITIVE CABLE FOR ABOUT 45 SECS. HOPE THIS HELPS DALE [email protected]
Old 06-07-2004, 02:46 PM
Re: Re: 1997 Grand Cherokee 4.0, new oxigen sensor and still code 21
Yes, Dale I did it,
but the problem is the check engine turns on again and a hesitate too
thanks for the reply
Old 06-07-2004, 05:23 PM
Thanks in advance.
HI, HOW MANY WIRES WERE ON YOUR ORGINAL OXYGEN SENSOR, IF IT HAD LESS WIRES OR MORE YOU MAYBE CUTTING OUT A CIRCUIT THAT WAS ON THE ORGINAL. DALE
[email protected]
Old 06-08-2004, 08:41 AM
[email protected]
My original sensor has 4 wires with the same colors as the replacement
Old 09-12-2004, 09:14 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
I know some models have 2 O2 sensors, one b4 the Cat, and 1 in the Cat, I think, maybe urs has the same, I will check real quick and let u know
Old 09-12-2004, 09:22 PM
Yes, there is 2 O2 sensors in ur model, 1 b4 the Cat, and 1 after the Cat.
did u replace them both, it may be the other one, or it could be just disconnected. check that they r both plugged in.
