Old 06-07-2004, 12:17 PM
blueturtle blueturtle is offline
Send a message via AIM to blueturtle
even more problems
well my car is giving me even more problems it seems lately that when i try to start my car it just wont turn on like it wants to start it turns over and everything but doesn't go, i thought nit was b/c my air filters dirty and wasn't gettin enough air but i just tried taking it off and starting it and no luck what are different scenario's that could cause this problem?
Old 06-07-2004, 01:13 PM
sykotic1 sykotic1 is offline
Re: even more problems
try changin the battery? new fuel filter? new oil filter? your air filter isnt gonna do that unless you have somethin really stuck in there.
Old 06-07-2004, 04:59 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
This could be a very wide range of problems..
First like Sykotic mentioned.. COndition of the battery? check it cold and hot.. An induction service or fuel injection/system cleaning usually helps quite a bit.. Change your fuel filter..
Does it start better when the engine is hot? or cold? Could be a leak in the fuel system, like a faulty FP regulator.. If the fuel system is all good, check the ignition system.. A weak coil? Bad wires or plugs? cap and rotor?
1991 Camaro Z28
Old 06-07-2004, 05:26 PM
Dober89 Dober89 is offline
Its pretty much either fuel or ignition. Pull each plug individually to check if your getting spark in all cylinders. Just dont zap yourself :P
Old 06-07-2004, 07:21 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
I have a similar problem.. car starts fine when hot (most of the time) on first key turn. when cold, first key turn will end in a slow start then die, second key turn will start with no problem, except very short (single) burst of smoke from exhaust. I suspect fuel delivery issues. It seems that the car doesn't maintain fuel pressure when turned off. I have replaced the gas tank cap already. wires, plugs, ign module, rotor, cap, coil are all new from other starting problem (that got fixed). Will fuel system job help me? What else do you think I should do?
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 06-07-2004, 09:27 PM
well i just changed the air filter and cap and rotor both the cap and rotor were so bad that the copper turned white and was so damn rough and the rotor was all black where it gets electricity soit was preaty burnt out anyways that seemed to be my problem b/c my car runs really good now all i need to really do is change the plugs and fuel filter spray some carb cleaner and thats it (oh and i too had edelbrock headers so i guess i gotta rip em off like 89 said)
