Old 06-07-2004, 11:08 AM
paragoat paragoat is offline
Lift for front suspension
I have a 01 extented cab silverado with a 3/4 drop. I installed air bags on the back and now i need a solution for the front coil springs to lift the suspension 1 to 3 inches when carrying a heavy load. The truck bottoms out very easily when loaded down. Does any one make a product that will lift a coil spring front end?
Thanks
  • 2001 Silverado Extra Cab 2WD 5.3 liter 3/4 drop
  • 2001 Pontiac Bonneville SSEi 180 degree thermostat
  • 1999 Suburban 5.7 4X4 K&N, Hypertech Stat, Hypertech Programmer, true dual exhaust with Flowmaster 50's
  • 1969 Pontiac GTO Judge, Ram Air 3, hideaways, Automatic
Old 06-07-2004, 01:06 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
I'm kinda of confused. Why or how does the front get affected when the rear is loaded down with stuff? You may as well get airbags up front to though. You could get Air Ride Shockwaves if you want an excellent ride and don't care about laying frame.
*Under Construction - New sig to debut*
Old 06-07-2004, 01:27 PM
Because the truck is slightly higher in the back (so i can have more travel in the springs while loaded) the front end of the front bumper is lower to the ground. The higher the rear end gets, it causes bottoming out and the bumper skirt/plastic oil pan cover hit the ground.
Old 06-09-2004, 12:29 AM
Okay, I got ya now. I know that there use to be some sort of coil springs with air bags inside them that were adjustable. But I'm unaware if they are still available or even that good. I'd recommend The Shockwave from Air Ride Technologies(www.ridetech.com). It would probably be the quickest and simpliest solution to your problem.
Old 06-10-2004, 09:04 PM
Red face
thanks for the info. boy those shocks are expensive 900.00 for the pair. The rear air bags only cost 200.00. I will look for the air bags that go in the center of the spring. They might be cheaper. I will take a look around.
