Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-07-2004, 11:08 AM
coronaking7 coronaking7 is offline
fuel filters
How do I locate and change the fuel filter on a 98 Acura integra
Old 06-09-2004, 01:37 PM
YellowITR479 YellowITR479 is offline
Re: fuel filters
If you are looking at the engine from the front bumper...look at you battery...then look just a little lright and you will see a black object with an brass top on it running to your fuel rail...that is the filter...make sure you disconnect your battery and take your fuel cap off to help relieve pressure and loosen the top nut to let out pressure also....dont overtighten too much or you wont get a good seal....im still having problems with mine thats how i know
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
