Yukon Auto4wd
Can you have your Yukon on Auto 4wd all the time?
Re: Yukon Auto4wd
The general answer is 'yes.' Can you provide more information about your truck, namely the model year?
Take care, Jerry
Take care, Jerry ------------------------------------------------------------------- '03 GMC Yukon Denali; www.suvworld.com/vroomvroom '04 GMC Yukon Denali XL; www.suvworld.com/mrsvroom '04 Toyota Tacoma XtraCab V6 4x4; www.toyotatruckworld.com/vroomvroom |
Hmmm, that's interesting; IIRC on the OBS GM fullsize SUV/trucks, the owners manual states that Auto4WD can be used when the pavement isn't dry (e.g., wet conditions) but not highly recommended when the road is dry...but perhaps the Autotrac has been changed with the NBS vehicles.
I do know that at least in '03, GM offered a full-time 4WD option (not the same one as the AWD found on the Denali--the primary distinction between the two is that the full-time 4WD option has 4LO; neither option has a 4HI button, BTW) that eliminated the need for the Auto4WD button offered in the Autotrac 4WD option found in GM full-sized SUV/trucks, so I reckon it would make no sense for GM to offer that Auto4WD can be used all the time (i.e., wet and dry roads) if they have a fulltime 4WD transfer case option available which can be used on both wet and dry pavement...not that you can force the full-time 4WD to operate in 2WD mode. Last edited by tonytone; 06-08-2004 at 12:00 PM. |
Re: Yukon Auto4wd
Tony - that's a good and interesting point. On my '02 Tahoe the sales person warned us against using the auto 4wd for extended driving. However, the owner's manual contradicted that advice.
Unless you have the need, it's probably wise to keep the vehicle in 2wd from a fuel economy standpoint, if nothing else. Take care, Jerry
Re: Yukon Auto4wd
Thanks |
Re: Yukon Auto4wd
It's probably safe to keep it in 'auto' but unless you have the need for it, you might want to keep it in 2wd., based on Tony's comments above. Do you have the owner's manual available? Also, I'd guess that 2wd would give you the best fuel economy. Good luck...
Take care, Jerry
Hey, tonytone,
I have a 04 Yukon SLT, on the sticker, it says it is "04 Yukon awd". However, it has a 4lo button just like you mentioned in your post. My sales person told me that it was just like Denali's AWD. I guess I got duped here? thanks |
Re: Yukon Auto4wd
I'll say this much--I wish the Denali had come with the full-time 4WD w/ available 4LO instead of AWD...or at least put in a limited slip or locking differential. If that salesperson told you that the Yukon full-time 4WD "was just like Denali's AWD"--ask him why the Denali doesn't have the 4LO button if such was indeed true... You didn't get duped...you had the misfortune (not your fault) of having to deal with a salesperson who obviously doesn't know enough of the product he/she is attempting to sell. |
Re: Yukon Auto4wd
RPO NR4 - AWD with 4 WD Low (AKA: AutoTrac)
RPO NR3 - AWD with out 4 WD Low (Denali) RPO NP8 - Auto 4WD, 4WD, 2WD, 4WD Low NR4 and NR3 use the same software algorithm to detect rear wheel slipage and put power to the front wheels, typically with in 300 ms. Yukons come standard with limited slip rear unless the vehicle is equiped with Stabilitrac (begining in MY05, you can have limited slip with Stabilitrac). Denalis come standard with Stabilitrac thus removing the limited slip rear and Stabilitrac is a option on the Yukons. Hope this clears up the mess a bit. |
Ok. this makes sense to me now.
I guess I have NP4. On the sticker it says it is AWD with AutoTrac. I also have a stability button in my truck. So, is what I have better or worse than denali version? thx! |
Re: Yukon Auto4wd
If your vehicle has Stabilitrak (RPO JL4) then you have the same drive system as in a Denali with the added 4 WD low feature.
Re: Yukon Auto4wd
IOW--you have it better than the Denali version, assuming of course you have a need for the 4LO...which in my guestimation will never be used by 95% (again, just a guess) of those people driving vehicles with 4LO capability.
Re: Re: Yukon Auto4wd
is it something with the stabilitrac??? |
Re: Re: Re: Yukon Auto4wd
Re: Yukon Auto4wd
tonytone - what does NBS mean as in "NBS Denali" ?
Thanks |
