Old 06-07-2004, 10:02 AM
tsiwithpsi20 tsiwithpsi20 is offline
Send a message via AIM to tsiwithpsi20
Runs better when cold ?
I don't know if this is a problem or not. But in the morning when i first run my car, and the temp guage is just below norm operating temp, the turbo slams to all hell and back and it runs pretty mean(enough torque to squeal my all wheel a little on a roll). But then as it gets up to about the middle position between the two notches in the temp guage(where my temp usually resides), the turbo still hits nice, but not near as hard. I have a boost controller set at 16 psi, on a small 16g turbo w/ stock 1g wastegate. Any way to retain this 'cold engine' turbo power?? is this a problem??
Old 06-07-2004, 11:25 AM
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
Re: Runs better when cold ?
it could just be the egine is still cold so the air that's goin into the intercooler doesn't get heat up as much. but you shouldn't drive it pass 3000rpm untill you reach the operating temp. bad bad! a FMIC will cool all that air down.
06 Charger SRT-8 black.
Old 06-07-2004, 08:58 PM
TurbosR4me's Avatar
TurbosR4me TurbosR4me is offline
Why would rpm past 3k be bad at cold temp? You know that most people at the drag strip push their car up the line to the pits to race on a cold engine?
Old 06-07-2004, 09:07 PM
the pistons and wall don't heat up at the same rate. without having all the components at the proper operating temp, we all know what would happen to one that's a lot hotter than the other, boom!!.. i'll leave that to your imagination.
