Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 06-07-2004, 09:16 AM
TheBman69 TheBman69 is offline
Angry 528Wagon A/C Problems
My AC has stopped.....when I push the blue snowflake AC button, it does not even light up!!!
One would think "fuse", but they are all ok....
For that matter, the orange "re-circulate" button does not work either!!
Any ideas?
Bman
Old 06-07-2004, 01:25 PM
jeffreyb4me jeffreyb4me is offline
Re: 528Wagon A/C Problems
bmw used several different IHK systems in E34's. if you've check ALL the fuses in the front E-box, sadly and while that little switch block might be bad, the most likely cause is a failed control unit [located between the heater box and firewall] you need to pull out the glovebox, consoled side cover[carpeted] and the air duct [3 phillips screws]...it simply sides out and unplugs.
