True duals????
have a 96 ext cab. I want to put true duals on her but have been told by co-worker's that I can't. I know someone here has true dual. Who makes the setup and how much?
Thanks |
Re: True duals????
What exactly do you mean by "true" duals?
Dude, I don't know. My truck came stock with duals (they come together and exit in only one exhaust pipe though), but I would check around at some of your local muffler shops and see what they have to say. Good luck!
2004 SRT-4 1998 GMC 2500 1996 Eagle Talon TSi AWD Turbo 1993 Eagle Talon TSi AWD Turbo 1985 Nissan 300ZX Turbo 1990 Nissan 300ZX Twin Turbo Past Z Cars Crew ![]() ![]() |
true duals go all the way back to the cat and require two mufflers. they can exit into two seperate pipes or be routed back to one. That's the way my 98 was. However, I sawed off both pipes after I had dual tips put on to make it LOUD as hell. Now my exhaust dumps out right under the cab. (a little annoying but worth it!)
True duals
True duals are exactly that. Most duals are your two headers merge into one goes into your muffler, then splits and two pipes come out. Ture duals are: each header goes into it's own muffler then exits to its pipe. Produces more horsepower..... always good!
Re: True duals????
True duals never come together like stock exhausts do. The muffler shop in town will not do this, because I wanted no cats, and no mufflers. They said it's illegal, but I paid a guy that works there enough, if you know what i mean, (a little under the table money exchange) and he did them after hours for me!!!
hehehe.....definetly boost horsies, and it sounds DAMN good too!!!
Matthew Brough ![]() 1997 Geo Prizm -- 301,000 miles 2000 Honda Accord -- 225,000 miles 2004 GMC Yukon XL -- 223,000 miles 1987 Jeep Comanche -- 116,000 miles |
Amen!!!!!!!!
Re: True duals????
After paying for the equipment (cats, mufflers, headers) about how much do you think the shop would charge to install it?
Re: True duals????
Thanks for the info, I will check around.
DL |
Re: True duals????
Well I looked into the same thing and a muffler shop here told me not to do it because I would start getting a service engine soon light. I went with just a catback system and guess what I am now getting a service engine soon light so good luck!!
Thats strange about your engine light comming on. I've never had that happen in my truck......
Re: True duals????
my engine light will come on every now and then, but not very often and usually when at WOT. BUT I LOVE THE WAY THAT SOUNDS AT WOT. Ignore it IF it is a trouble code for the emissions system.
Re: True duals????
I lost alittle milage because i put on 2" pipes. fixed it and put on 2" 1/2 pipes and brought my milage back up. I am getting around 24 to 26 mpg doing 70 on average speed. 1996 5.7L vortec
A 96 350 should already have dual cats and then both pipes go into one big muffler. It is not illegal to convery to two mufflers, But is illegal to remove the cats. I had the muffler removed and had twin mufflers installed and a balance tube installed between the pipes to keep back pressure equal and it is legal. I didn't really gain anything except a nice rumble because the stock exaust on a vortec already flows well.All four O2 sensors still function and no SES light. On a 96 you can't remove the cats or the computer will go berzerk and the truck will run like sheet!!
Re: True duals????
For the love of God where do you gentlemen here some of this stuff. You can put true duel on anything yes anything..... Ok putting duels on a 96 chevy truck is a great idea . The only o2 sensor you need it the front 2 , yes by removing the back 2 you will tripe a code but that code tell the computer nothing more the cat arent work it doesnt change anything nor does it harm or hurt the motor or computer. The front o2 sensors are the only one the computer depends on for the right are fuel mixture . The back do nothing as far a leaning it out or fatting it up !!!!! As far as vortec 5.7 flow good anyway that is false .. Any system the you install headers on with make a dramatic difference in power gas and gas milage ..
