Old 06-07-2004, 02:28 AM
RT Thunder Rider RT Thunder Rider is offline
Send a message via AIM to RT Thunder Rider Send a message via Yahoo to RT Thunder Rider
Question Clarion vs. Infinity
what would be the better speaker to get, the Clarion SRX6993 or the Infinity KAPPA 693.5I. i have a 90 honda prelude with 2 12 Kicker Solo Baric L5's in a seal box soon to be in a ported box. Also i have had the back deck customized to hold 6x9's in sealed boxs.Here are the specs on the 2 sets of speakers.
Clarion SRX6993
Diameter 6x9 Inch
Sensitivity 92 dB
Frequency response 28-30000 Hz
RMS Power Range 60 Watts
Peak Power Handling 200 Watts
Features
Dual Concentric Design
Polylaminate Woofer Cone
3/4" Silk Soft Dome Tweeter
Removable Tweeter for Replacement or Separate
2-Way Tweeter Mounting (Flush or Surface)
Strontium Magnet
2-Way 12dB/oct. Passive Crossover
Rubber Surround
200 Watts Maximum Music Power
Diameter 6x9 Inch
Sensitivity 90 dB
Frequency response 35-22000 Hz
RMS Power Range 2-110 Watts
Peak Power Handling 330 Watts
Features
Plus One C.M.M.D. woofer cone is 30% larger than other speakers of this Size, ensuring strong bass response
High-roll rubber surround allows greater woofer movement
1" C.M.M.D. dome tweeter
1-1/8" metallic planar EMIT supertweeter
2-way external crossovers (18 dB/octave, 3,500 Hz high- and low-pass)
Sensitivity 90 dB
Frequency response 35-22,000 Hz
Recommended power range 2-110 watts RMS
Peak power handling 330 watts
Top-mount depth 3-1/4"
If theres a better set of 6x9's out that cost 300 or under, i am open to suggests.
Old 06-07-2004, 04:59 AM
Little Burner's Avatar
Little Burner Little Burner is offline
Send a message via AIM to Little Burner
I would go with Clarion
_________
Friends help you move
Real friends help you move body's
~TeaM~MindgamE~
Pic's of my ride
Old 06-07-2004, 06:24 AM
sofast's Avatar
sofast sofast is offline
Send a message via AIM to sofast Send a message via MSN to sofast Send a message via Yahoo to sofast
I havent had any 6x9 in Kappas but I have had the Clarions. They sounded excelent. My best 6x9 have been Mb quart. You can get them fro under $300.
[IMG][/IMG]
Old 06-10-2004, 08:04 PM
integrasedan integrasedan is offline
i have all clarion speakers, with front JL Audio tweeter. Although I wish i had Infinity instead. Clarions are okay, but i like Infinity sounds better.
Best way is too listen to them in the shop and see which you like. I wouldn't buy speakers unless I hear how they sound.
Old 06-11-2004, 08:31 AM
Icantgetno Icantgetno is offline
Re: Clarion vs. Infinity
I prefer the sound of the infinitys but would suggest using something other than 6x9's :/
