Old 06-07-2004, 01:26 AM
candp candp is offline
1.0 compression test
on not running engine,100,108,and 110 compression reading is this good compression or need for rings? on the 1.0 96 metro?thanks
Old 06-07-2004, 06:05 AM
westsidex's Avatar
westsidex westsidex is offline
According to geozukigti, the compression should be 170-185 psi, so your compression is low. This can be caused by worn or wearing valves, a blown head gasket, or worn piston rings. Find out what the problem is before doing the work, you don't want to rip out the pistons only to find out the rings were good and the problem lies in the valves. What is your mileage and has the car been well maintained?
Get to Know Geo Metro: The Small Car with Big Ideas - http://geodriver.tripod.com.
Old 06-07-2004, 04:25 PM
geozukigti geozukigti is offline
Drop a about a half shot-glass of oil in the cylinder through the spark plug hole, and then do the compression test. if the compression jumps, your rings are shot. If it stays low, your valves or headgasket is leaking, or your rings are REALLY shot.
