Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 06-06-2004, 11:22 PM
Rhcmlc Rhcmlc is offline
Send a message via AIM to Rhcmlc
Recharging a/c
I plan to buy an a/c recharge kit for my v6 Malibu but I need to know which a/c hose the kit needs to be connected to. I noticed the a/c on the Malibu has two hoses. Please help.
Old 06-07-2004, 07:27 AM
BeatnikTermite BeatnikTermite is offline
When recharging an A/C system always use the low side. On the V6 Malibu, this is located just in front of the firewall, behind the accessory belt routing. NEVER USE THE HIGH SIDE TO CHARGE! This is the one just above the radiator.
Since the A/C needs to be running while charging, I need to tell you to also be very careful not to let your forearm touch the belt while you are trying to get to the fill valve.
I had lots of problems charging mine last week. I finally bought the fill hose with the pressure gauge built in (as directed by sparkn on my previous post http://www.automotiveforums.com/vbul...d.php?t=232246) and discovered why I had so much trouble. I didn't have the fill hose properly connected. I only discovered this when I saw that there was no low side pressure reading.
As of Friday night, mine is charged and cooling.
Old 06-07-2004, 11:15 PM
Re: Recharging a/c
Which freon is used to recharge the Malibu?
Old 06-07-2004, 11:29 PM
speed1628 speed1628 is offline
Send a message via AIM to speed1628
Re: Re: Recharging a/c
use the R134 FREON the kit u buy to charge the A/C comes with a hose that will only hook up to the low side service port.
