Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 06-06-2004, 10:50 PM
RB25240kouki's Avatar
RB25240kouki RB25240kouki is offline
Send a message via AIM to RB25240kouki
dumb mistake
alright... laugh now, get it out of your system. Heres the story... got in my car today and started to crank it... no dice. Acted like a dead batt... so i had a dude jump me off... well when i went to turn the lights on it died. went to jump it again and i put the cables on backwards... ZAP! the cable started to spark... i reconected it in them the right way and got it started and then let it run... Now the seat belt and door lights, and the clock flickers. the beeper is also much quiter... im guessing i screwed up the interior CPU... if anyone has any other ideas please let me know. And if it is the CPU then does anyone have one for sale and are S4 and S5 interchangeable? Thanks
1989 GTUs
JDM Turbo II motor
Custom exuast: gutted pre-cat, high flow 3" cat. Ypipe into two 2.5 inch pipes with N1 sytle cans.
Walbro 255 fuel pump
Pivot headlight controller
More mods to come
Happy Rotoring
Old 06-06-2004, 11:53 PM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
Re: dumb mistake
all I have to say is, that blows
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 06-07-2004, 12:52 AM
J-Rat's Avatar
J-Rat J-Rat is offline
Send a message via AIM to J-Rat Send a message via MSN to J-Rat
Re: dumb mistake
Oh man....
1988 10th AE Edition TII
More mods then you have.
Old 06-07-2004, 04:34 AM
DevoutWankelist's Avatar
DevoutWankelist DevoutWankelist is offline
Send a message via ICQ to DevoutWankelist Send a message via AIM to DevoutWankelist
Re: dumb mistake
Sorry to hear that man, good luck on the fix.
BAH!, went to change my sig and forgot what I was supposed to put here. . .
Old 06-08-2004, 07:56 PM
replaced a few fuses that blew and some that just looked old and GUESS WHAT... no more flickering... i have narrowed the problems down to the batt. and alternator. I planed on doing a rear mount battery but just not this soon so o well. If its the alternator ill put an FD alternator on there (1300cc.com has the how too on that one) and mabey get it remanufactured to higher output (or buy it like that in the first place if they have one). But Ill do the battery first. First off does anyone know of a good battery box... I dont need the kit because ive got the hook up on wiring so i just need a battery box. I dont feel like paying $200 for one but i want a metal one. Also does anyone know where to get the optima red top batteries at? Well thanks for your concern so far and thanks for any help you can give me. Rotor on!
1989 GTUs
JDM Turbo II motor
More mods to come
Happy Rotoring
Old 01-13-2006, 12:29 AM
kavlic76 kavlic76 is offline
Re: dumb mistake
Hi,
I thought I was the only guy who did that. I`ve also did a similar thing and messed up the whole electrical system. The CD player does not work, the memory of the radio is gone (i need to set everytime i restart the car), when I open the door the radio shuts down, and many weird things. Not too major things, but still makes you mad. I was thinking of changing the CPU. ANy suggestions?
Thanks
Old 01-13-2006, 11:26 PM
fcdriver fcdriver is offline
Re: Re: dumb mistake
Originally Posted by kavlic76
Hi,
Thanks
Check all the fuses before you change anything, then if it still doesn't work pull the radio and check to see if you still have constant power to the radio on one wire (forget what wire it is but you should notice it if you hooked the radio up yourself).
Originally Posted by dampachi
Violence isn't always the answer..but sometimes..depending on the question..it can be the answer.
