Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 06-06-2004, 09:57 PM
Turbo13 Turbo13 is offline
Angry 3000 GT Glove Box Lock
Hi,
Can someone who has a VR4 1995 or later look at their Glove Box.
Mine will not open, (the lock is broken), I need advice on the best way to remove it. Sometimes looking inside helps....
I have two option (I think)
1. Drill out the lock, then buy new one.
2. Cut the metal Hook that the lock locks into. I can see the top portion of the hook, and am thinking of using a hacksaw blade to cut it. Then I hope I can replace that.
So can someone look at their car and tell me what looks better. Maybe the hook is not very replacable after I cut it ?
Please help ASAP I need to get in to get my unlock code for the stereo its in the glove box...
I have 1995 VR4.
Thanks a million.
Old 06-07-2004, 09:42 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
When mine seized up some time ago, the locksmith basically drilled it out so it could be opened. He then jury-rigged up the latch system so it could be opened and closed by sliding a lever.
Resistance Is Futile (If < 1ohm)
Old 06-07-2004, 11:41 PM
PearlGT PearlGT is offline
mine has a problem where its just a bitch to open and you basically have to grab the 2 sides of it and jiggle it around until it'll finally get loose, doesn't bother me much though seeing as i expected some minor imperfections in an older 93 model
Old 06-08-2004, 01:53 AM
OneHotV6's Avatar
OneHotV6 OneHotV6 is offline
Send a message via Yahoo to OneHotV6
Mine doesn't even lock... I only have one key, the ignition key, is there a seperate key for the glove box lock?
Sorry, don't mean to jack the thread..
2005 Ford Mustang GT
1993 Nissan Sentra XE
2005 Nissan Sentra S
My cardomain page
Old 06-08-2004, 08:39 AM
Unhappy Solution
Ok, For all that might need the answer.
I ended up hack sawing the "Striker" - this is the hook inside the glove box that the lock would catch on.
In any case I sawed that in half and thus opened the box. Striker is a $3 part so I thought that was a good deal at first. Note even though the handle for the glove box is on the left the actual lock is in the middle. I took just the blade and it slid in between the dash and the glove box ...
There is a plastic nut that turns the assembly at the end of the handle (inside) it was worn. So when the lock turns the assembly does not. I am currently trying to see if I can get a replacement for it. It might come with the lock then its $60 . As always its a lousy 2cent plastic piece that is needed.
Old 10-16-2004, 08:14 PM
nos_exhaust nos_exhaust is offline
Hey Turbo, did you ever try PearlGT's strategy. I'm also having problems with my lock and don't know if i'm ready to commit to sawing the lock.
Old 10-16-2004, 08:19 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: 3000 GT Glove Box Lock
Nos, turbo13 hasn't been on AF for 4 months.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 10-17-2004, 05:17 PM
YogsVR4's Avatar
On older threads that you want to talk to a poster about, please use the PM system.
Closed Thread
