Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-06-2004, 08:47 PM
danforth45's Avatar
danforth45 danforth45 is offline
Arrow 97 rodeo rear wheel alignment?
I have a 97 4X4 rodeo 3.2 auto and I have noticed that my drivers side rear wheel is set further out (1in.) than the passengers side rear wheel. does alyone know if rodeo's are supposed to be that way due to alignment? or is my axle out of place?
Old 06-07-2004, 08:50 AM
rodeo02 rodeo02 is offline
There's nothing to adjust/align on a solid rear axle truck- like a rodeo. are both rear rims the same? are both rear tires the exact same size?
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 06-07-2004, 07:59 PM
danforth45's Avatar
Re: 97 rodeo rear wheel alignment?
yes, all four are the stock 16 inch wheels with 225/75 dayton tires.
Old 06-08-2004, 12:01 PM
rheteric rheteric is offline
Send a message via AIM to rheteric
Is your track bar bent???
2000 Rodeo LS 4x4
3.2L w/cone filter
Full Manik S/S package
Old 06-08-2004, 06:01 PM
danforth45's Avatar
track bar? what do you mean
Old 06-08-2004, 09:18 PM
There is a bar running laterally connecting your frame and your axle.... it keeps the axle from moving side to side. If it is bent, then this would result in a shorter length from point to point, and cause it to be offset.
2000 Rodeo LS 4x4
3.2L w/cone filter
Old 06-09-2004, 04:15 PM
danforth45's Avatar
ok, thanks ill go take a look. Where does it connect to on the frame and axle?
