Go Back   Automotive Forums Car Chat > Cars in General
Old 06-06-2004, 05:41 PM
stillen_69 stillen_69 is offline
neon lights
i have one red neon light under my dash that i bought from walmart that plugs into the cig lighter..anyways i i got another one would splicing the wires together be a good idea for another one? or would it cause any malfunctions?
Old 06-12-2004, 09:30 PM
93rollaracer's Avatar
93rollaracer 93rollaracer is offline
Send a message via AIM to 93rollaracer
Re: neon lights
nope...it'll work fine.
i have 5 wires spliced together in my car and it hasn't caught on fire...yet
Proud member of DAMM: Drunks Against Mad Mothers
Originally Posted by vinnym86
Metalheads: 93rolleracer
crazy sons of bitches who get hammered, break shit, and scream. yeah, they're pretty cool. right up to the point when they lynch a black guy.
Old 07-14-2004, 05:20 PM
Vinny03 Vinny03 is offline
Send a message via AIM to Vinny03
Re: neon lights
i wud say get a switch and a fuse and run it to your car battery its a lot easier that way
Old 07-16-2004, 06:40 AM
pro_am pro_am is offline
Send a message via MSN to pro_am Send a message via Yahoo to pro_am
Re: neon lights
lol "hasn't caught on fire...yet"
Jake
Old 07-16-2004, 08:27 PM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
Re: neon lights
Since those lights require so little energy tag on wiring is ok.
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
Old 07-16-2004, 09:46 PM
individuel individuel is offline
i just got a blue one but mine isnt running for some reason, i got a switch with three terminals ground, acc and power, i split the neon wire in two and used the stripe one for acc and the other one for ground, this is the part i think i messed up on, i used speaker wire if thats ok and used the copper side for power and ran it to my fuse box to the switch, then for the other half, i used it for grounding but it still does not work, someone please tell me whats wrong..
Old 07-17-2004, 12:41 AM
Unhappy
anybody?
Old 07-17-2004, 01:47 PM
Re: neon lights
speaker wire is no good u wanna use the same gauge wire. go to home depot with a small pce of it i think is 16 gauge
Xtreme Creations
Manalapan, NJ
We do everything and anything to your car
we will even sell you parts regardless where u live
just contact vinny @ [email protected]
Old 07-17-2004, 07:55 PM
oh ok
Old 08-06-2004, 03:00 AM
StreetGlow10 StreetGlow10 is offline
Re: neon lights
yep...vinneys right..thats basicly what u want to do...i got a switch and i wired 1 wire to the lights, 1 wire to ground, and the other wire i ran to my fuse box and wired it to my cigarette lighter fuse. But if thats what u plan on doing you might want to get smaller wiring then 16 gauge. My fuses are small and i barely got it to fit because the wiring was too big for the fuse but i made some adjustments and its all good now
Old 08-06-2004, 03:09 AM
lowS-DIME lowS-DIME is offline
Re: neon lights
to splice the other neon into the existing one i would just use a three-way but connecter on the power wire from the new on to the power wire if the old one... then just ground the other side to whatever... i would also get rid of that cigarette lighter thing and plug it into the battery..
plans for my new car....
Old 08-06-2004, 03:03 PM
Re: neon lights
yeah but if you use the fuse it doesnt run your battery down...well i guess it depends how often you have them on...From sundown to sun up i have my neons on so i would run the battery down so i have it to the fuse instead.
Old 08-06-2004, 05:43 PM
NeonAtron NeonAtron is offline
Re: neon lights
just go to pep boys, auto zone, or any other car place and get the 2 slot adapter (not sure on the name) but then you can just plug that into the cig lighter and then youll have 2 slots. i believe it will def short if you try to twist them together.
Old 08-07-2004, 11:20 AM
Re: neon lights
I went to walmart and looked at the neon underdash lights , do not splice wires or youll pop fuses left right and center they are specifically set for one light.
Old 08-07-2004, 11:25 AM
Re: Re: neon lights
Wow neons suck that much juice out of the battery? That doesnt seem right cus the alternator shouldnt have a problem with such a small power source bein added to it. Do what I did , test your charging system with all your electrical stuff on and see how much drain there is on the battery and see if the alternator compinsates and keeps it at a decent level of charge.
