Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-06-2004, 10:37 AM
meet07 meet07 is offline
turbo wont boost??
about 2 months ago i put a custom manifold,ss Autochrome wastegate, and a new remanufactured Airesearch turbocharger. ran for one day then it start making this weird noise and wouldnt boost anymore. so i figured it was my manifold since it had cracked in the past so therefore i replaced it with a stainless steel one. the new one has all the apropriate gaskets and the wastegate is hooked up correctly.
drove it and made thesame noise. now i hit like 1 psi on occasions but nothing higher. now also i noticed that my turbo wheel has a wable in it. i was wondering if this would cause my setup not to boost cause i blocked of the wastegate as well to make sure it would definitly spool up but nothing. this setup is on a 90 prelude and im getting very tired of messing with it. can someone help. is it the turbo????
there are no leaks, just a weird noise thats really loud
new b21a
custom intake
dc sports header
custom exhaust
3a racing muffler
zex-55 shot
zex bottler warmer
ichiban shift knob
17" inch black team dynamic(motorsports)
yokahama
vis body kit
lund hood scoops
euro headlights
white w/ blue pearl paint
apr gtII spoiler
Old 06-06-2004, 11:36 AM
TURBOACCORD TURBOACCORD is offline
Re: turbo wont boost??
if you can't pin point where the noise is comming from...the easiest thing to do is to buy an automotive scope...(similar to what a dr. will use in a checkup)...this will help you determine whether it is the bearing in the turbo or something more serious...one way to tell if it makes any boost what so ever is to take the hose off the compressor houseing that goes to the wastegate....drive it down the raod maybe a 1/4 mile and watch the boost gauge....if it makes boost then the turbo is good and it may be more of a wastgate problem...
Old 06-06-2004, 12:00 PM
YellowITR479 YellowITR479 is offline
"now also i noticed that my turbo wheel has a wable in it". Dude, that cant be good at all. Did you physically try to wobble the impeller, cause if it wobbles than your turbo is definately on its way out. You also said that your maifold isnt cracked and you have no boost leaks....pretty much the only thing left is the turbo. Does your car smoke at all?
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 06-06-2004, 08:52 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Re: Re: turbo wont boost??
A turbo will have a little side to side play in it. That is very common and there is noting to worry about. Now if your turbo has in and out play, then its only a matter of time
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 06-07-2004, 12:15 AM
it dosnt have side to side and in and out. it just wabbles. like when i 1st noticed it my wheel use to stick to the compressor housing. not the fins are curled up a little and the clearance is much greater than it should be??? so while it is spinning and u look at it the center section goes in a little circle.
new b21a
custom intake
dc sports header
custom exhaust
3a racing muffler
zex-55 shot
zex bottler warmer
ichiban shift knob
yokahama
vis body kit
lund hood scoops
euro headlights
apr gtII spoiler
Old 06-07-2004, 11:49 AM
Hypsi87's Avatar
how can it not have play in any direction but still wobble???? Grab the nut on the end of the compressor wheel. Then wobble it side to side. That is side to side play, this is ok. Now take and try to push it in and out, this is in and out play, this is not good.
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 06-07-2004, 01:00 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
you wouldnt be able to describe the noise now would you ?
Team Lonely Drivers
Old 06-07-2004, 01:04 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
I think what he is describing is a bent shaft, not a shot bearing. The bearing is fine, so it wont wiggle side to side, but if you spin it, the compressor wheel doesnt stay still, the end of the shaft moves around in a circle... Its not moving because its loose, its moving because its bent.. If this is the case, same situation.. your turbo is fucked. Get a new one or have yours rebuilt. You will probably need at least a new shaft, maybe new bearings, and most likely a new compressor wheel, since that one probably has hit the inside of the compressor housing.
Old 06-07-2004, 01:40 PM
Hypsi87's Avatar
Even if the bearings are fine, you will still have side to side wobble! very little but you still have it.
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 06-07-2004, 04:58 PM
it is doing exactly what dupox said. i no that side and in-out are normal but it wables like the center of the turbine shaft is moving in a little circle. it makes a loud whistling/hufing noise like someone is blow without using there lips...lol it seems that my turbo is fucked but with this would it not boost. i already went to turbonetics and im looking at a t3/t4 hybrid
thanx
new b21a
custom intake
dc sports header
custom exhaust
3a racing muffler
zex-55 shot
zex bottler warmer
ichiban shift knob
yokahama
vis body kit
lund hood scoops
euro headlights
apr gtII spoiler
